"ill defined primitiveEntry starting for pressure file boundary conditions |
May 21, 2018, 23:51 |
zein elserfy
Rep Power: 8 |
I am trying to model flow over aerofoil using simple foam,after importing geometry and modifying boundary conditions in p & u files and running the case ,i got this message
__________________________________________________ ____________________ Create time Create mesh for time = 0 SIMPLE: convergence criteria field p tolerance 1e-05 field U tolerance 1e-05 field nuTilda tolerance 1e-05 Reading field p --> FOAM FATAL IO ERROR: "ill defined primitiveEntry starting at keyword 'exit*' on line 29 and ending at line 57" file: /home/zels496/OpenFOAM-in-Box-18.02/OpenFOAM-dev/tutorials/incompressible/simpleFoam/airFoil2D/airfoiltry/0/p at line 57. From function void Foam:rimitiveEntry::readEntry(const Foam::dictionary&, Foam::Istream&) in file db/dictionary/primitiveEntry/primitiveEntryIO.C at line 189. FOAM exiting __________________________________________________ ____________________ this is the p file : /*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: dev | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volScalarField; object p; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 2 -2 0 0 0 0]; internalField uniform 0; boundaryField { inlet { type freestreamPressure; } exit { type freestreamPressure; } top { type freestreamPressure; } bottom { type freestreamPressure; } aerofoil { type zeroGradient; } front { type empty; } back { type empty; } } ------------------------------------------------------------------------------------------------------------------ p and u files are uploaded on these links https://www.4shared.com/file/5SldABKYda/p_online.html https://www.4shared.com/file/qD7eu3eXda/U_online.html Last edited by zeinelserfy; May 22, 2018 at 03:19. |
[foam-extend.org] Problems installing foam-extend-4.0 on openSUSE 42.2 and Ubuntu 16.04 | ordinary | OpenFOAM Installation | 19 | September 3, 2019 18:13 |
[foam-extend.org] problem when installing foam-extend-1.6 | Thomas pan | OpenFOAM Installation | 7 | September 9, 2015 21:53 |
[swak4Foam] swak4foam building problem | GGerber | OpenFOAM Community Contributions | 54 | April 24, 2015 16:02 |
ParaView Compilation | jakaranda | OpenFOAM Installation | 3 | October 27, 2008 11:46 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 17:51 |
