StitchMesh - defining patch
Old   May 18, 2018, 09:45
Default StitchMesh - defining patch
Kristina
KKV_88 is on a distinguished road
Hello everyone,
First to say that I'm new in this field and this is my attempt to set the first simulation. I created a mesh using blockMesh and, since the geometry is quite complex, 2 regions has occured.
My idea is to use a stitchMesh function to merge these regions, and I started with a simple case presented in a tutorials simple_cube, modified it and get the final mesh with one region.
The problem that I'm facing now is running a simulation on this mesh. I created simple case of laminar 3D flow using simpleFoam (laminar_box case) with the same geometry, and tried to set these parameters on stitched mesh (simple_cube case), but it returns an error about the definition of patches for the faces that has been merged in 0 folder. My question is what should be set for them (since they are now internal faces) in 0 folder when defining initial conditions? I checked, ther is no face associated to these patches in checkMesh log file. Both cases, laminar_box and simple_cubes are attached.
Thank you in advance ,
KKV_88
KKV_88 is offline   Reply With Quote
Old   May 20, 2018, 19:15
Kristina
Problem solved , similar example was given in:
https://www.cfd-online.com/Forums/op...e-patches.html
stitchmesh patch
y+ and u+ values with low-Re RANS turbulence models: utility + testcase florian_krause OpenFOAM 114 August 23, 2023 06:37
Near wall treatment in k-omega SST Arnoldinho OpenFOAM Running, Solving & CFD 38 March 8, 2017 14:48
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 19:57
[Gmsh] Import gmsh msh to Foam adorean OpenFOAM Meshing & Mesh Conversion 24 April 27, 2005 09:19
Multicomponent fluid Andrea CFX 2 October 11, 2004 06:12
