May 8, 2018, 17:44 |
OpenFOAM Parallel Run Problem
Javier Palacios
hello everybody,
I'm trying to run engineFoam in parallel 2 machines(32 cores), in both i have install OpenFOAM v5, a shared file system(NFS), same username, ssh communication without password, also i can run normally the case in each machine. I've been digging in this forum, and try all the solutions i have found, but nothing seems to do the trick. the problem its that when i lunch the case like this: Code:
mpirun --hostfile /home/halfblood/nfsshare/nodes -np 4 engineFoam -parallel Code:
192.xxx.xx.61 cpu = 2 192.xxx.xx.62 cpu = 2 Code:
-------------------------------------------------------------------------- [[48743,1],0]: A high-performance Open MPI point-to-point messaging module was unable to find any relevant network interfaces: Module: OpenFabrics (openib) Host: mech-02 Another transport will be used instead, although this may result in lower performance. -------------------------------------------------------------------------- /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 5.x | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 5.x-197d9d3bf20a Exec : engineFoam -parallel Date : May 08 2018 Time : 11:46:29 Host : "mech-02" PID : 28023 I/O : uncollated [mech-02:28020] 3 more processes have sent help message help-mpi-btl-base.txt / btl:no-nics [mech-02:28020] Set MCA parameter "orte_base_help_aggregate" to 0 to see all help / error messages i try to block the other network interfaces Code:
mpirun --mca btl_tcp_if_exclude 'eno1, eno2, lo, ens1f0, docker0, ens1f0' --hostfile /home/halfblood/nfsshare/nodes -np 16 engineFoam -parallel also i have try to modify the decomposeParDict: Code:
numberOfSubdomains 4; //method simple; method scotch; //simpleCoeffs //{ // n (2 2 1); // delta 0.001; //} distributed yes; roots 3( "/home/halfblood/nfsshare/OpenFOAM/halfblood-5.0/run/engineFoam/kivaTest" "/home/halfblood/nfsshare/OpenFOAM/halfblood-5.0/run/engineFoam/kivaTest" "/home/halfblood/nfsshare/OpenFOAM/halfblood-5.0/run/engineFoam/kivaTest" ) the case i'm running is the tutorial engine foam. Beforehand thanks for taking the time to help me. |
November 27, 2019, 00:01 |
Maximus Arelius
Rep Power: 9 |
Could you limit the communication to a specified interface and check:
1. Check the interface using of the nodes using Code:
ssh <NODE> netstat -nr Code:
--mca btl_tcp_if_include eth0
-- 🃏Maximus🃏 Last edited by godfatherBond; November 29, 2019 at 00:00. |
cluster, distributed parallel, enginefoam, openfoam 5.0, parallel |
[snappyHexMesh] Problem with parallel run of snappyHexMesh | Lorenzo92 | OpenFOAM Meshing & Mesh Conversion | 5 | April 15, 2016 04:12 |
p_rgh problem during parallel run | musahossein | OpenFOAM Running, Solving & CFD | 0 | November 23, 2014 09:01 |
Running Error using Compressible OpenFoam Parallel mode | dhendria | OpenFOAM Running, Solving & CFD | 0 | February 13, 2014 20:53 |
OpenFOAM doesn't run in parallel | callumso | OpenFOAM Running, Solving & CFD | 0 | July 11, 2013 12:17 |
Problem on Parallel Run Setup | Hamidur Rahman | CFX | 0 | September 23, 2007 17:11 |
