Set cell volume integrated field values to preserve integral
Old   April 30, 2018, 11:01
Default Set cell volume integrated field values to preserve integral
Andrea Di Ronco
Diro7 is on a distinguished road
Hello to everyone!
What I'm doing is basically scalar transport with a custom solver which I wrote by adding a scalar transport equation to simpleFoam.
Since for the moment I'm simulating point sources, I created a source volScalarField Qc which is set to zero everywhere except for a single cell, using setFields:
defaultFieldValues
    volScalarFieldValue Qc 0
regions
    nearestToCell
        points ((0.02 0.015 0));
        fieldValues
            volScalarFieldValue Qc 1
The cell is selected with nearestToCell, which looks for the nearest cell to a specified cartesian point.
I would like to impose the total scalar source rate (e.g. in kg/s) located at the specific point, but setFields obviously sets the volume field, meaning that the value I set in setFieldsDict (1 in the above example) would be the "volume averaged" one, so that the volume integral of the source field would depend on the volume of the specific cell.
At the beginning I was using a simple geometry and a structured mesh, so that I could knew the cell volume in advance. Now I need to use an unstructured mesh and to move the position of the source from one simulation to another.
Is there any simple way to set the volume-integral value instead of the volume-average one to the cell (or, equivalently, to know the specific cell volume)?
Thanks in advance,
Andrea
EDIT: another way of putting it would be to get the volume of the cellSet in which the source is defined. I'm no expert with OpenFOAM, but maybe it would be easier to manipulate a "cellSet entity" rather than a "cell" itself. The cellSet can be easily created with topoSet, and being able to calculate its volume would be a more general procedure (like in the case of non-point source). Unfortunately I've been reasoning about this possibility, but I couldn't find anything on this forum
Diro7 is offline   Reply With Quote
Old   June 3, 2018, 01:47
fumiya's Avatar
Fumiya Nozaki
fumiya is on a distinguished road
You can use the SemiImplicitSource fvOption to specify your mass source.
There is the volumeMode entry and you can choose absolute option.
https://github.com/OpenFOAM/OpenFOAM...plicitSource.H
[Personal]
fumiya is offline   Reply With Quote
Old   June 3, 2018, 11:44
Andrea Di Ronco
Hi fumiya,
thank you very much for your reply. I'm not expert with using fvOptions, but it seems very useful so I'll definitely go and see what I can do with it.
Regarding my initial problem, I solved it by writing a slightly modified version of setFields which computes the total volume of the cell set and divides the source intensity by it before setting the field.
Thank you again!
Andrea
cell volume, setfields, source terms
[swak4Foam] About groovyBC to set distributed fixedGradient values for each cell boundary patch nwpukaka OpenFOAM Community Contributions 6 August 12, 2014 07:34
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 07:20
FvMatrix coefficients shrina OpenFOAM Running, Solving & CFD 10 October 3, 2013 15:38
