OpenFOAM - Error at faceAgglomerate
Old   March 29, 2018, 09:39
Default OpenFOAM - Error at faceAgglomerate
Kikuta Enoki
Kikuta.K is on a distinguished road
Hello Foamers.
I am using chtMultiRegionReactingFoam (a hybrid solver of chtMultiRegionFoam and rectingFoam) to calculate axisymmetric gas burner model like attached image Fig.1.(Fig.1 is calculated by reactingFoam)
I am facing the problem (errors) at a stage of faceAgglomerate command.
In log.faceAgglomerate.gasPhase, it says “Wedge patch ‘front’ is not planar”.
My setting is as follows, which is believed fine (if not, let me know)
convertToMeters 1;
vertices
(0 0 0)
(0.049809725 -0.004357775 0)
(0.049809725 0.004357775 0)
(0 0 0.15)
(0.049809725 -0.004357775 0.15)
(0.049809725 0.004357775 0.15)
blocks
hex (0 1 2 0 3 4 5 3) (50 1 150) simpleGrading (1 1 1)
edges
boundary
front
type wedge;
faces
(0 1 4 3)
back
type wedge;
faces
(0 2 5 3)
sideWall
type wall;
faces
(1 2 5 4)
inlet
type patch;
faces
(0 1 2 0)
outlet
type patch;
faces
(3 4 5 3)
axis
type empty;
faces
(0 3 3 0)
mergePatchPairs
Hopefully anyone could help me to fix this problem?
For your reference, a zip file of dace directory and example picture calculated by reactingFoam is attached.
Best regards.
(My OpenFOAM is version 4.x)
[IMG]www.me.tut.ac.jp/ece/kikuta/fig1_axisymmetricGasBurnerModelExapmle.png
[/IMG]www.me.tut.ac.jp/ece/kikuta/pif5.zip
Kikuta.K is offline   Reply With Quote
faceagglomerate, not planar, openfoam
Frequently Asked Questions about Installing OpenFOAM wyldckat OpenFOAM Installation 3 November 14, 2023 12:58
OpenFOAM Foundation releases OpenFOAM® 3.0.0 CFDFoundation OpenFOAM Announcements from OpenFOAM Foundation 1 November 7, 2015 16:16
OpenFOAM Foundation Releases OpenFOAM v2.3.0 opencfd OpenFOAM Announcements from OpenFOAM Foundation 3 December 23, 2014 04:43
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 04:52
64bitrhel5 OF installation instructions mirko OpenFOAM Installation 2 August 12, 2008 19:07
