February 23, 2018, 14:30 |
Issue in creating ACMI
Nicola Casari
Hello and good evening,
I am encountering an annoying issue while creating ACMI interfaces. Particularly, when the createBaffle utility calculates the faceAreaWeight, I get a bad points error. Code:
--> FOAM FATAL ERROR: Bad points:(0.0488523 -0.0409136 0.0101859) (0.0488523 -0.0409136 0.0101859) (0.0488523 -0.0409136 0.0101859) From function void Foam::plane::calcPntAndVec(const point&, const point&, const point&) in file meshes/primitiveShapes/plane/plane.C at line 90. FOAM aborting In the attachment, the boundary mesh and the bad-overlapping points depicted in red. The mesh is ok (high non-orthogonality warnings at the most). Any ideas on how to fix this? Many thanks in advance. Nicola Last edited by Roversella; February 25, 2018 at 09:34. Reason: typo |
February 28, 2018, 20:00 |
#2 | |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings Nicola,
Just in case the report https://bugs.openfoam.org/view.php?id=2860 - is ever deleted, here is part of what I wrote there: Quote:
Essentially if the createBaffles utility has problems with a triangle that is defined by 3 identical points, then clearly something very weird happened during the generation of the mesh. I don't know how you've generated this very interesting mesh (looks like a lobular pump), but I suspect that the existing two mesh regions (checkMesh mentions this) is the main reason why it was not possible to create the contact baffles, given that if they are not connected, then there is nothing to separate. Best regards, Bruno
March 1, 2018, 04:48 |
Nicola Casari
Dear Bruno,
Many thanks for your reply, and sorry if the bug report did not follow the issue tracker rules. Actually, the problem is not that I have two separate regions ( which is indeed required for building ACMI interfaces, see Sliding interface- ACMI #20). This is probably related to the way we are developing to account for the motion. I will let you know if I manage to fix the problem. Regards, Nicola |
acmi, bad points, normal vector |
[SOWFA] NREL SOWFA ABLTerrainSolver tutorial problem | cico0815 | OpenFOAM Community Contributions | 36 | February 3, 2022 12:54 |
apparent anomalies at ACMI interface | jimteb | OpenFOAM Running, Solving & CFD | 20 | July 23, 2018 10:19 |
[ICEM] Issue creating geometry and trim surfaces | M4x1m | ANSYS Meshing & Geometry | 1 | February 9, 2015 09:38 |
[DesignModeler] Issue creating a mesh around a 3D "whale-wing" | hmatt415 | ANSYS Meshing & Geometry | 1 | November 21, 2014 04:09 |
[ICEM] Issue moving vertices after creating C-grid | johnp | ANSYS Meshing & Geometry | 3 | November 10, 2010 16:49 |
