Decomposing mesh
Old   February 5, 2018, 04:50
Default Decomposing mesh
Phibo is on a distinguished road
Hello Foamers,
when I decompose my geometry meshed with SHM into 2 regions with the scotch method, there is something left out in the pressure boundary condition. I defined an outlet with totalPressure BC and specified gamma for the fluid. However, after decomposing the gamma is set to the default value 1. The same problem appears when I use mapFields and the patch only exists in the target geometry.
Has anyone an idea what I might be doing wrong? Any help would be much appreciated. I am working with OF 4.1.
Thanks!
Phibo is offline   Reply With Quote
Old   February 5, 2018, 08:24
Found the solution! In order to specify a gamma > 1 you have to handle the fluid as supersonic compressible and therefore also specify psi (or thermosi) in the totalPressure BC as its default value is "none".
decomposepar, mapfields, pressure bc, totalpressure
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 08:38
Star CCM Overset Mesh Error (Rotating Turbine) thezack Siemens 7 October 12, 2016 12:14
[ICEM] surface mesh merging problem everest ANSYS Meshing & Geometry 44 April 14, 2016 07:41
[ICEM] Problem making structural mesh on a surface froztbear ANSYS Meshing & Geometry 1 November 10, 2011 09:52
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 22:11
