RacMat
Rep Power: 13 ![]() |
I have a LES field of a 2D geometry (so x: streamwise, y: wall normal and z: spanwise). I decided to increase the domain size in the z direction so the geometry remains the same but i increase the spanwise length of the domain. Does anyone know how to use the mapFields utility to so that i can somehow map my old (smaller domain data) on to the new domain with a larger z direction size? Thanks! |
NKR
Rep Power: 0 ![]() |
have u found solution to this problem?
Herpes Free Engineer
Rep Power: 12 ![]() |
Google is your friend. If you still insist not to use Google: https://openfoamwiki.net/index.php/MapFields https://www.openfoam.com/documentati...s.html#details
The OpenFOAM community is the biggest contributor to OpenFOAM: User guide/Wiki-1/Wiki-2/Code guide/Code Wiki/Journal Nilsson/Guerrero/Holzinger/Holzmann/Nagy/Santos/Nozaki/Jasak/Primer Governance Bugs/Features: OpenFOAM (ESI-OpenCFD-Trademark) Bugs/Features: FOAM-Extend (Wikki-FSB) Bugs: OpenFOAM.org How to create a MWE New: Forkable OpenFOAM mirror |
interpolation, mapfields |
Using the mapFields utility | sweisenb | OpenFOAM Pre-Processing | 2 | May 18, 2015 15:54 |
Difficulty with mapFields utility | rnburne | OpenFOAM Pre-Processing | 0 | June 2, 2014 16:33 |
The -parallel parameter of mapFields utility in OpenFOAM v2.3.0 | shuoxue | OpenFOAM Pre-Processing | 1 | April 28, 2014 05:59 |
mapFields utility | openfoammaofnepo | OpenFOAM | 2 | June 29, 2013 16:55 |
mapFields utility | cristobal | OpenFOAM | 1 | April 1, 2010 11:09 |
