PimpleDyMFoam --Simulate turbulence caused by moving object
Old   January 13, 2018, 06:10
Default PimpleDyMFoam --Simulate turbulence caused by moving object
jiahui_93 is on a distinguished road
Hi, I would like to simulate the turbulence and airflow caused by the movement of elevator car in the shaft, including the airflow surrounding the car and within the whole shaft.
I set my initial condition as:
U
internalField uniform (0 0 0);
boundaryField
carTop
type movingWallVelocity;
value $internalField;
carSide
carBase
shaftTop
type zeroGradient;
shaftSide
type fixedValue;
value uniform (0 0 0);
shaftBase
type fixedValue;
P
internalField uniform 0;
boundaryField
carTop
type zeroGradient;
carSide
type zeroGradient;
carBase
type zeroGradient;
shaftTop
type totalPressure;
p0 uniform 0;
shaftSide
type zeroGradient;
shaftBase
type zeroGradient;
k
internalField uniform 0.375;
boundaryField
carTop
type kqRWallFunction;
value uniform 0.375;
carSide
carBase
shaftTop
type zeroGradient;
shaftSide
shaftBase
epsilon
internalField uniform 14.855;
boundaryField
carTop
type epsilonWallFunction;
value uniform 14.855;
carSide
carBase
shaftTop
type zeroGradient;
shaftSide
shaftBase
nut
boundaryField
carTop
type nutkWallFunction;
value uniform 0;
carSide
value uniform 0;
carBase
value uniform 0;
shaftTop
type zeroGradient;
shaftSide
value uniform 0;
shaftBase
value uniform 0;
I expect to see some velocity or pressure contour, but the U and P is uniform along the shaft and throughout car surface. I had attached the picture for results.
Sorry for my dummy question. I would be very grateful if there's someone to suggest any correction to be done. Thanks
jiahui_93 is offline   Reply With Quote
Old   January 13, 2018, 06:17
Default Velocity contour aimed to get
I'm sorry. But my post had limited 5 attachments. So I posted another to attach the picture i aim to get. Thanks
A problem using reactingParcelFoam to simulate turbulence liyuthu OpenFOAM Running, Solving & CFD 1 February 3, 2016 11:43
Is OpenFOAM capable to simulate a floating object with variable density? Idosar OpenFOAM 0 September 29, 2015 17:13
Compilation error OF1.5-dev on Suse10.3 darenyang OpenFOAM Installation 0 April 29, 2009 05:55
object moving in a pipe david chua FLUENT 0 November 25, 2005 03:50
A moving object within a chamber Whitaker FLUENT 5 October 10, 2000 23:02
