January 10, 2018, 15:01 |
initial residual = nan
Ewald
Hello evreyone,
when i run my simulation i get these errormesseges: Starting time loop forceCoeffs forces: Not including porosity effects Time = 0.0001 Courant Number mean: 7.96332e-08 max: 1.02137e-05 smoothSolver: Solving for Ux, Initial residual = nan, Final residual = nan, No Iterations 1000 smoothSolver: Solving for Uy, Initial residual = nan, Final residual = nan, No Iterations 1000 GAMG: Solving for p, Initial residual = nan, Final residual = nan, No Iterations 1000 GAMG: Solving for p, Initial residual = nan, Final residual = nan, No Iterations 1000 --> FOAM FATAL IO ERROR: wrong token type - expected Scalar, found on line 0 the word 'nan' file: /home/thorbrue/CFDe/HA2/system/data.solverPerformance.p at line 0. From function operator>>(Istream&, Scalar&) in file lnInclude/Scalar.C at line 93. FOAM exiting I guess, this is a general problem, like too high/low timesteps or something? I use pisoFoam, Checkmesh gives me no errors, turbulence is turned off, however openfoam wanted me to define a "k" and "omega" file, which i don't understand as well. I already tried "deltaTs" from 0.1 to 0.0001 but this wount make much of a difference. I hope someone has an idea or hint. Thank you in advance! |
nan, resudal |
HeatSource BC to the whole region in chtMultiRegionHeater | xsa | OpenFOAM Running, Solving & CFD | 3 | November 7, 2016 05:07 |
Wrong fluctuation of pressure in transient simulation | caitao | OpenFOAM Running, Solving & CFD | 2 | March 5, 2015 21:33 |
calculation stops after few time steps | sivakumar | OpenFOAM Running, Solving & CFD | 7 | March 17, 2013 06:37 |
Orifice Plate with a fully developed flow - Problems with convergence | jonmec | OpenFOAM Running, Solving & CFD | 3 | July 28, 2011 05:24 |
Could anybody help me see this error and give help | liugx212 | OpenFOAM Running, Solving & CFD | 3 | January 4, 2006 18:07 |
