Mass Flow Splitting for OpenFoam Outflow Boundary Conditions?
Old   December 11, 2017, 17:50
Default Mass Flow Splitting for OpenFoam Outflow Boundary Conditions?
Alexa
nephina is on a distinguished road
Hi all,
I am looking for a solution to a particular problem with multiple outflows, my project is blood vessels that split into multiple outflows. I have flow rates at inlets and outlets. If I directly apply these flowrates, the solution doesnt converge. I resolved this problem in ANSYS Fluent by using the outflow option for my outlet and assigning the outflow percentage from each outlet as is shown in this link:
http://www.afs.enea.it/project/neptunius/docs/fluent/html/ug/node247.htm (under boundary conditions
So, my question is: is there a boundary condition in openfoam5 that will let me split the mass flow? I have not had much luck finding it by going through the boundary condition source code.
Thanks for any help!
nephina is offline   Reply With Quote
Old   September 10, 2019, 11:04
Anna Bauer
franzsch is on a distinguished road
Hello nephina,
have you figured out if this is possible in OpenFOAM?
franzsch is offline   Reply With Quote
Old   September 10, 2019, 11:42
Carlo_P
Carlo_P is on a distinguished road
You can if you create different patches.
For each patch you can set the massFlow.
WARNING MassFlowRate in Inlet and Outlet is not so stable
Carlo_P is offline   Reply With Quote
boundary condition, flow rate weighting, fractional flow rate, mass flow splitting, multiple outlets
Wind turbine simulation Saturn CFX 60 July 17, 2024 06:45
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 08:38
Velocity vector in impeller passage ngoc_tran_bao CFX 24 May 3, 2016 22:16
Setting rotating frame of referece. RPFigueiredo CFX 3 October 28, 2014 05:59
Overflow Error in Multiphase Modelling with Two Continuous Fluids ashtonJ CFX 6 August 11, 2014 15:32
