December 2, 2017, 14:33 |
Internal Patches from SnappyHexMesh
Tommy Mello
Rep Power: 11 |
All, I'm writing to gain a better understanding of creating internal patches from snappyHexMesh. I have been using the snappyMultiRegionHeater tutorial in conjunction with a few other snappy / external flow cases.
I would like to know how you typically define patches when using snappy I am currently having trouble getting all of the target cells into an internal patch (sometimes I get 10 out of 100 cells). I have a piece of equipment exhausting gas in a large surrounding environment. The exhaust input to the domain is represented as a surface (zero thickness) on one of the faces of the equipment (large box). Code:
geometry { equipment.stl { type triSurfaceMesh; name equipment; scale 0.001; regions { equipment { name equipment; } exhaust // Sometimes this is a separate stl { name exhaust; } } } Code:
refinementSurfaces { equipment { level (4 4); patchInfo { type wall; } } exhaust { level (4 4); patchInfo { type patch;} faceZone exhaust; cellZone exhaust; cellZoneInside inside; } Is this an stl tolerance issue? Am I missing a few steps or files in the process (createPatch, createBaffles, setSet topoSet,..etc.)? Thanks for the help! Last edited by twinturbotom; December 2, 2017 at 20:04. |
December 2, 2017, 20:53 |
Works with no overlap, is a non overlap a requirement?
Tommy Mello
Rep Power: 11 |
Foam::error::PrintStack | almir | OpenFOAM Running, Solving & CFD | 92 | May 21, 2024 08:56 |
[snappyHexMesh] snappyHexMesh does not create boundary patches from .stl files | bug_or_feature | OpenFOAM Meshing & Mesh Conversion | 7 | August 30, 2016 20:18 |
Possible bug with stitchMesh and cyclics in OpenFoam | Jack001 | OpenFOAM Pre-Processing | 0 | May 21, 2016 09:00 |
[snappyHexMesh] On which patches to set BC's for snappyHexMesh ? | Talder | OpenFOAM Meshing & Mesh Conversion | 0 | November 8, 2015 19:25 |
[snappyHexMesh] internal faces between patches created with snappyHexMesh | romant | OpenFOAM Meshing & Mesh Conversion | 0 | August 17, 2009 09:40 |
