Is it possible to define a reference pressure cell somewhere in the internalField?
Old   November 29, 2017, 06:56
Default Is it possible to define a reference pressure cell somewhere in the internalField?
pawlo is on a distinguished road
Hi!
I want to simulate a closed room with a combustion device inside that room with OpenFOAM 2.3.
The device is not part of the simulation, i am doing all combustion calculations with swak4foam.
So basically the device in my simulation is just a "cut out" cuboid inside the room.
One patch of this cuboid is the "suck in" side (lets call it outlet), and the opposite patch is the inlet into the simulation domain.
The device sucks in the gas in the room, heats it up and releases it at the other side of the device.
At the outlet i have to prescribe a constant volume flux and at the inlet i prescribe a time dependant volume flux.
The time dependency is given by my swak4foam routine, witch ensures a constant mass in the room for all times.
Since i have to prescribe two volume flux / velocity boundary conditions, i can not prescribe pressure at these boundaries.
So my question is, if it is possible to select a cell in the internalField at witch i can set a reference pressure?
Right now i solved it by prescribing a constant pressure at one of the other patches of the device-cuboid.
The simulation runs very well but the velocity at this pressure-patch is a bit ugly... .
I would prefer to just set one single cell in the domain as pressure reference, preferably somewhere near a wall where the velocity will be almost zero anyway.
pawlo is offline   Reply With Quote
internalfield, pressure reference cell
Laminar Kinetic Energy Model (Walters 2008) logoswort Fluent UDF and Scheme Programming 2 May 19, 2017 20:41
Compression stoke is giving higher pressure than calculated nickjuana CFX 62 May 19, 2015 14:32
OpenFOAM 1.6-ext git installation on Ubuntu 11.10 x64 Attesz OpenFOAM Installation 45 January 13, 2012 13:38
Installing OF 1.6 on Mac OS X gschaider OpenFOAM Installation 129 June 19, 2010 10:23
Missing math.h header Travis FLUENT 4 January 15, 2009 12:48
