November 28, 2017, 11:14 |
Boundary conditions for water depth
Ellen H
Rep Power: 8 |
Hi there,
I'm trying to model a boundary condition, where the water column height changes based on a time series. So it would only be a phase change in height, not a change in velocity or pressure. The idea is that the increased water level will force water to flow onto a surface with different depressions and pool in lower areas. All based on gravity. My time series is fairly simple: 01/01/2011 00:00:00 9.7 m 01/01/2011 00:05:00 9.7 m 01/01/2011 01:00:00 10.35 m 01/01/2011 11:00:00 10.35 m 01/01/2011 12:00:00 9.7 m 01/01/2011 20:00:00 9.7 m Does anyone know how I can achieve this? I'm using a rectangular prism geometry right now to represent the water at the initial level. |
boundary conditions, water column, water level |
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 07:38 |
Radiation in semi-transparent media with surface-to-surface model? | mpeppels | CFX | 11 | August 22, 2019 07:30 |
Multiphase flow - incorrect velocity on inlet | Mike_Tom | CFX | 6 | September 29, 2016 01:27 |
Basic Nozzle-Expander Design | karmavatar | CFX | 20 | March 20, 2016 08:44 |
Question about heat transfer coefficient setting for CFX | Anna Tian | CFX | 1 | June 16, 2013 06:28 |
