Problem with Mixing Plane of test Turbine
Old   November 2, 2017, 13:33
Default Problem with Mixing Plane of test Turbine
Henrik Johansson
HenrikJohansson is on a distinguished road
Been searching for a solution for quite some time now but can't find any.
I have regions, Stator and Rotor, which are cyclicGgi at 45degree and a mixing plane between the Stator and Rotor. I'm using MRFSimplefoam to get stuff spinning at 3000 rpm.
I create two separate cases where i mesh the Stator and Rotor separate using HELYS-OS. The MP patch meshes are not comformal but are fairly close.
Mixing plane Meshing with HELYX-OS
1 Make two separate models with separate meshes
2 <mergeMeshes $HOME/Documents/Turbine/Mesh Stator_Mesh $HOME/Documents/Turbine/Mesh Rotor_Mesh>
3 Copy polyMesh from Rotor/1 and all files from Rotor/constant/triSurface and Stator/constant/triSurface to "Mixing_Plane_Turbine"/constant. If you have B.C.'s setuped already don't copy boundary file. Change (nFaces) and (startFace) according to the new mesh
4 New terminal with openfoam
5 <checkMesh>
6 <topoSet>
7 <setSet -batch setBatch.batch>
8 <setsToZones -noFlipMap>
9 New terminal with foam extended
10 <checkMesh>
12 Save the folder by copying it with a new name "org. name - yy-mm-dd hh:mm"
But when I do #10 and run checkMesh I get the following:
| \\      /  F ield         | foam-extend: Open Source CFD                    |
|  \\    /   O peration     | Version:     4.0                                |
|   \\  /    A nd           | Web:         http://www.foam-extend.org         |
|    \\/     M anipulation  | For copyright notice see file Copyright         |
Build    : 4.0-54c9f83b540c
Exec     : decomposePar
Date     : Nov 02 2017
Time     : 18:08:38
Host     : henrik-linux
PID      : 3614
CtrlDict : "/home/henrik/Documents/Turbine/Mixing_Plane/system/controlDict"
Case     : /home/henrik/Documents/Turbine/Mixing_Plane
nProcs   : 1
SigFpe   : Enabling floating point exception trapping (FOAM_SIGFPE).
Create time
Time = 0
Create mesh for region region0
Initializing the GGI interpolator between master/shadow patches: Periodic_Left/Periodic_Right
Initializing the GGI interpolator between master/shadow patches: Periodic_Left_1/Periodic_Right_1
Initializing the mixingPlane interpolator between master/shadow patches: MixP_Stator/MixP_Rotor
*** Error in `decomposePar': double free or corruption (!prev): 0x0000000005e3ef80 ***
======= Backtrace: =========
/lib/x86_64-linux-gnu/libc.so.6(+0x777e5)[0x7f0b667c97e5]
/lib/x86_64-linux-gnu/libc.so.6(+0x8037a)[0x7f0b667d237a]
/lib/x86_64-linux-gnu/libc.so.6(cfree+0x4c)[0x7f0b667d653c]
/home/henrik/foam/foam-extend-4.0/lib/linux64GccDPOpt/libfiniteVolume.so(_ZNK4Foam16GGIInterpolationINS_14PrimitivePatchINS_4faceENS_4ListERKNS_5FieldINS_6VectorIdEEEES6_EESA_E19maskedSlaveToMasterIS6_EEvRKNS4_IT_EERSE_RKNS3_IiEE+0x23c)[0x7f0b69d3a0ac]
/home/henrik/foam/foam-extend-4.0/lib/linux64GccDPOpt/libfiniteVolume.so(_ZNK4Foam12ggiPolyPatch11interpolateINS_6VectorIdEEEENS_3tmpINS_5FieldIT_EEEERKS7_+0x271)[0x7f0b69d3c461]
/home/henrik/foam/foam-extend-4.0/lib/linux64GccDPOpt/libfoam.so(_ZNK4Foam12ggiPolyPatch24calcReconFaceCellCentresEv+0x179)[0x7f0b67d277a9]
/home/henrik/foam/foam-extend-4.0/lib/linux64GccDPOpt/libfoam.so(_ZNK4Foam12ggiPolyPatch20reconFaceCellCentresEv+0x19)[0x7f0b67d27a39]
/home/henrik/foam/foam-extend-4.0/lib/linux64GccDPOpt/libfoam.so(_ZN4Foam16polyBoundaryMesh10updateMeshEv+0x2ae)[0x7f0b67d67ebe]
/home/henrik/foam/foam-extend-4.0/lib/linux64GccDPOpt/libfoam.so(_ZN4Foam8polyMeshC1ERKNS_8IOobjectE+0xfff)[0x7f0b67d9c38f]
/home/henrik/foam/foam-extend-4.0/lib/linux64GccDPOpt/libfiniteVolume.so(_ZN4Foam6fvMeshC2ERKNS_8IOobjectE+0x2b)[0x7f0b69cbde4b]
decomposePar[0x61f77b]
decomposePar[0x4ceaf2]
/lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf0)[0x7f0b66772830]
decomposePar[0x4d85e9]
======= Memory map: ========
00400000-0069c000 r-xp 00000000 08:05 5116851                            /home/henrik/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/decomposePar
0089b000-008ad000 r--p 0029b000 08:05 5116851                            /home/henrik/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/decomposePar
008ad000-008ae000 rw-p 002ad000 08:05 5116851                            /home/henrik/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/decomposePar
01f57000-06a31000 rw-p 00000000 00:00 0                                  [heap]
7f0b58000000-7f0b58021000 rw-p 00000000 00:00 0
7f0b58021000-7f0b5c000000 ---p 00000000 00:00 0
7f0b5c420000-7f0b64621000 rw-p 00000000 00:00 0
7f0b64621000-7f0b6468a000 r-xp 00000000 08:05 4986835                    /home/henrik/foam/foam-extend-4.0/lib/linux64GccDPOpt/liblduSolvers.so
7f0b6468a000-7f0b64889000 ---p 00069000 08:05 4986835                    /home/henrik/foam/foam-extend-4.0/lib/linux64GccDPOpt/liblduSolvers.so
7f0b64889000-7f0b6488b000 r--p 00068000 08:05 4986835                    /home/henrik/foam/foam-extend-4.0/lib/linux64GccDPOpt/liblduSolvers.so
7f0b6488b000-7f0b6488c000 rw-p 0006a000 08:05 4986835                    /home/henrik/foam/foam-extend-4.0/lib/linux64GccDPOpt/liblduSolvers.so
7f0b6488c000-7f0b6488d000 rw-p 00000000 00:00 0
7f0b6488d000-7f0b64898000 r-xp 00000000 08:05 6820566                    /lib/x86_64-linux-gnu/libnss_files-2.23.so
7f0b64898000-7f0b64a97000 ---p 0000b000 08:05 6820566                    /lib/x86_64-linux-gnu/libnss_files-2.23.so
7f0b64a97000-7f0b64a98000 r--p 0000a000 08:05 6820566                    /lib/x86_64-linux-gnu/libnss_files-2.23.so
7f0b64a98000-7f0b64a99000 rw-p 0000b000 08:05 6820566                    /lib/x86_64-linux-gnu/libnss_files-2.23.so
7f0b64a99000-7f0b64a9f000 rw-p 00000000 00:00 0
7f0b64cab000-7f0b64cc1000 r-xp 00000000 08:05 6820560                    /lib/x86_64-linux-gnu/libnsl-2.23.so
7f0b64cc1000-7f0b64ec0000 ---p 00016000 08:05 6820560                    /lib/x86_64-linux-gnu/libnsl-2.23.so
7f0b64ec0000-7f0b64ec1000 r--p 00015000 08:05 6820560                    /lib/x86_64-linux-gnu/libnsl-2.23.so
7f0b64ec1000-7f0b64ec2000 rw-p 00016000 08:05 6820560                    /lib/x86_64-linux-gnu/libnsl-2.23.so
7f0b64ec2000-7f0b64ec4000 rw-p 00000000 00:00 0
7f0b64ec4000-7f0b64ecc000 r-xp 00000000 08:05 6820562                    /lib/x86_64-linux-gnu/libnss_compat-2.23.so
7f0b64ecc000-7f0b650cb000 ---p 00008000 08:05 6820562                    /lib/x86_64-linux-gnu/libnss_compat-2.23.so
7f0b650cb000-7f0b650cc000 r--p 00007000 08:05 6820562                    /lib/x86_64-linux-gnu/libnss_compat-2.23.so
7f0b650cc000-7f0b650cd000 rw-p 00008000 08:05 6820562                    /lib/x86_64-linux-gnu/libnss_compat-2.23.so
7f0b650cd000-7f0b650d6000 r-xp 00000000 08:05 1844006                    /usr/lib/x86_64-linux-gnu/libltdl.so.7.3.1
7f0b650d6000-7f0b652d5000 ---p 00009000 08:05 1844006                    /usr/lib/x86_64-linux-gnu/libltdl.so.7.3.1
7f0b652d5000-7f0b652d6000 r--p 00008000 08:05 1844006                    /usr/lib/x86_64-linux-gnu/libltdl.so.7.3.1
7f0b652d6000-7f0b652d7000 rw-p 00009000 08:05 1844006                    /usr/lib/x86_64-linux-gnu/libltdl.so.7.3.1
7f0b652d7000-7f0b652e1000 r-xp 00000000 08:05 1844133                    /usr/lib/x86_64-linux-gnu/libnuma.so.1.0.0
7f0b652e1000-7f0b654e0000 ---p 0000a000 08:05 1844133                    /usr/lib/x86_64-linux-gnu/libnuma.so.1.0.0
7f0b654e0000-7f0b654e1000 r--p 00009000 08:05 1844133                    /usr/lib/x86_64-linux-gnu/libnuma.so.1.0.0
7f0b654e1000-7f0b654e2000 rw-p 0000a000 08:05 1844133                    /usr/lib/x86_64-linux-gnu/libnuma.so.1.0.0
7f0b654e2000-7f0b654e4000 r-xp 00000000 08:05 6820648                    /lib/x86_64-linux-gnu/libutil-2.23.so
7f0b654e4000-7f0b656e3000 ---p 00002000 08:05 6820648                    /lib/x86_64-linux-gnu/libutil-2.23.so
7f0b656e3000-7f0b656e4000 r--p 00001000 08:05 6820648                    /lib/x86_64-linux-gnu/libutil-2.23.so
7f0b656e4000-7f0b656e5000 rw-p 00002000 08:05 6820648                    /lib/x86_64-linux-gnu/libutil-2.23.so
7f0b656e5000-7f0b6571e000 r-xp 00000000 08:05 1845085                    /usr/lib/x86_64-linux-gnu/libhwloc.so.5.6.8
7f0b6571e000-7f0b6591d000 ---p 00039000 08:05 1845085                    /usr/lib/x86_64-linux-gnu/libhwloc.so.5.6.8
7f0b6591d000-7f0b6591e000 r--p 00038000 08:05 1845085                    /usr/lib/x86_64-linux-gnu/libhwloc.so.5.6.8
7f0b6591e000-7f0b6591f000 rw-p 00039000 08:05 1845085                    /usr/lib/x86_64-linux-gnu/libhwloc.so.5.6.8
7f0b6591f000-7f0b659af000 r-xp 00000000 08:05 1976508                    /usr/lib/openmpi/lib/libopen-pal.so.13.0.2
7f0b659af000-7f0b65baf000 ---p 00090000 08:05 1976508                    /usr/lib/openmpi/lib/libopen-pal.so.13.0.2
7f0b65baf000-7f0b65bb3000 r--p 00090000 08:05 1976508                    /usr/lib/openmpi/lib/libopen-pal.so.13.0.2
7f0b65bb3000-7f0b65bb7000 rw-p 00094000 08:05 1976508                    /usr/lib/openmpi/lib/libopen-pal.so.13.0.2
7f0b65bb7000-7f0b65bbc000 rw-p 00000000 00:00 0
7f0b65bbc000-7f0b65c31000 r-xp 00000000 08:05 1976504                    /usr/lib/openmpi/lib/libopen-rte.so.12.0.2
7f0b65c31000-7f0b65e30000 ---p 00075000 08:05 1976504                    /usr/lib/openmpi/lib/libopen-rte.so.12.0.2
7f0b65e30000-7f0b65e31000 r--p 00074000 08:05 1976504                    /usr/lib/openmpi/lib/libopen-rte.so.12.0.2
7f0b65e31000-7f0b65e34000 rw-p 00075000 08:05 1976504                    /usr/lib/openmpi/lib/libopen-rte.so.12.0.2
7f0b65e34000-7f0b65e36000 rw-p 00000000 00:00 0
7f0b65e36000-7f0b65e43000 r-xp 00000000 08:05 1845092                    /usr/lib/libibverbs.so.1.0.0
7f0b65e43000-7f0b66043000 ---p 0000d000 08:05 1845092                    /usr/lib/libibverbs.so.1.0.0
7f0b66043000-7f0b66044000 r--p 0000d000 08:05 1845092                    /usr/lib/libibverbs.so.1.0.0
7f0b66044000-7f0b66045000 rw-p 0000e000 08:05 1845092                    /usr/lib/libibverbs.so.1.0.0
7f0b66045000-7f0b6605d000 r-xp 00000000 08:05 6820613                    /lib/x86_64-linux-gnu/libpthread-2.23.so
7f0b6605d000-7f0b6625c000 ---p 00018000 08:05 6820613                    /lib/x86_64-linux-gnu/libpthread-2.23.so
7f0b6625c000-7f0b6625d000 r--p 00017000 08:05 6820613                    /lib/x86_64-linux-gnu/libpthread-2.23.so
7f0b6625d000-7f0b6625e000 rw-p 00018000 08:05 6820613                    /lib/x86_64-linux-gnu/libpthread-2.23.so
7f0b6625e000-7f0b66262000 rw-p 00000000 00:00 0
7f0b66262000-7f0b6627b000 r-xp 00000000 08:05 6820658                    /lib/x86_64-linux-gnu/libz.so.1.2.8
7f0b6627b000-7f0b6647a000 ---p 00019000 08:05 6820658                    /lib/x86_64-linux-gnu/libz.so.1.2.8
7f0b6647a000-7f0b6647b000 r--p 00018000 08:05 6820658                    /lib/x86_64-linux-gnu/libz.so.1.2.8
7f0b6647b000-7f0b6647c000 rw-p 00019000 08:05 6820658                    /lib/x86_64-linux-gnu/libz.so.1.2.8
7f0b6647c000-7f0b6652e000 r-xp 00000000 08:05 1976501                    /usr/lib/openmpi/lib/libmpi.so.12.0.2
7f0b6652e000-7f0b6672e000 ---p 000b2000 08:05 1976501                    /usr/lib/openmpi/lib/libmpi.so.12.0.2
7f0b6672e000-7f0b6672f000 r--p 000b2000 08:05 1976501                    /usr/lib/openmpi/lib/libmpi.so.12.0.2
7f0b6672f000-7f0b6673f000 rw-p 000b3000 08:05 1976501                    /usr/lib/openmpi/lib/libmpi.so.12.0.2
7f0b6673f000-7f0b66752000 rw-p 00000000 00:00 0
7f0b66752000-7f0b66912000 r-xp 00000000 08:05 6820467                    /lib/x86_64-linux-gnu/libc-2.23.so
7f0b66912000-7f0b66b12000 ---p 001c0000 08:05 6820467                    /lib/x86_64-linux-gnu/libc-2.23.so
7f0b66b12000-7f0b66b16000 r--p 001c0000 08:05 6820467                    /lib/x86_64-linux-gnu/libc-2.23.so
7f0b66b16000-7f0b66b18000 rw-p 001c4000 08:05 6820467                    /lib/x86_64-linux-gnu/libc-2.23.so
7f0b66b18000-7f0b66b1c000 rw-p 00000000 00:00 0
7f0b66b1c000-7f0b66b32000 r-xp 00000000 08:05 6820505                    /lib/x86_64-linux-gnu/libgcc_s.so.1
7f0b66b32000-7f0b66d31000 ---p 00016000 08:05 6820505                    /lib/x86_64-linux-gnu/libgcc_s.so.1
7f0b66d31000-7f0b66d32000 rw-p 00015000 08:05 6820505                    /lib/x86_64-linux-gnu/libgcc_s.so.1
7f0b66d32000-7f0b66e3a000 r-xp 00000000 08:05 6820537                    /lib/x86_64-linux-gnu/libm-2.23.so
7f0b66e3a000-7f0b67039000 ---p 00108000 08:05 6820537                    /lib/x86_64-linux-gnu/libm-2.23.so
7f0b67039000-7f0b6703a000 r--p 00107000 08:05 6820537                    /lib/x86_64-linux-gnu/libm-2.23.so
7f0b6703a000-7f0b6703b000 rw-p 00108000 08:05 6820537                    /lib/x86_64-linux-gnu/libm-2.23.so
7f0b6703b000-7f0b671ad000 r-xp 00000000 08:05 1835196                    /usr/lib/x86_64-linux-gnu/libstdc++.so.6.0.21
7f0b671ad000-7f0b673ad000 ---p 00172000 08:05 1835196                    /usr/lib/x86_64-linux-gnu/libstdc++.so.6.0.21
7f0b673ad000-7f0b673b7000 r--p 00172000 08:05 1835196                    /usr/lib/x86_64-linux-gnu/libstdc++.so.6.0.21
7f0b673b7000-7f0b673b9000 rw-p 0017c000 08:05 1835196                    /usr/lib/x86_64-linux-gnu/libstdc++.so.6.0.21
7f0b673b9000-7f0b673bd000 rw-p 00000000 00:00 0
7f0b673bd000-7f0b673c4000 r-xp 00000000 08:05 6820621                    /lib/x86_64-linux-gnu/librt-2.23.so
7f0b673c4000-7f0b675c3000 ---p 00007000 08:05 6820621                    /lib/x86_64-linux-gnu/librt-2.23.so
7f0b675c3000-7f0b675c4000 r--p 00006000 08:05 6820621                    /lib/x86_64-linux-gnu/librt-2.23.so
7f0b675c4000-7f0b675c5000 rw-p 00007000 08:05 6820621                    /lib/x86_64-linux-gnu/librt-2.23.so
7f0b675c5000-7f0b675c8000 r-xp 00000000 08:05 6820491                    /lib/x86_64-linux-gnu/libdl-2.23.so
7f0b675c8000-7f0b677c7000 ---p 00003000 08:05 6820491                    /lib/x86_64-linux-gnu/libdl-2.23.so
7f0b677c7000-7f0b677c8000 r--p 00002000 08:05 6820491                    /lib/x86_64-linux-gnu/libdl-2.23.so
7f0b677c8000-7f0b677c9000 rw-p 00003000 08:05 6820491                    /lib/x86_64-linux-gnu/libdl-2.23.so
7f0b677c9000-7f0b68388000 r-xp 00000000 08:05 4986462                    /home/henrik/foam/foam-extend-4.0/lib/linux64GccDPOpt/libfoam.so
7f0b68388000-7f0b68587000 ---p 00bbf000 08:05 4986462                    /home/henrik/foam/foam-extend-4.0/lib/linux64GccDPOpt/libfoam.so
7f0b68587000-7f0b685b1000 r--p 00bbe000 08:05 4986462                    /home/henrik/foam/foam-extend-4.0/lib/linux64GccDPOpt/libfoam.so
7f0b685b1000-7f0b685be000 rw-p 00be8000 08:05 4986462                    /home/henrik/foam/foam-extend-4.0/lib/linux64GccDPOpt/libfoam.so
7f0b685be000-7f0b685dd000 rw-p 00000000 00:00 0
7f0b685dd000-7f0b689bf000 r-xp 00000000 08:05 4986836                    /home/henrik/foam/foam-extend-4.0/lib/linux64GccDPOpt/libtetFiniteElement.so
7f0b689bf000-7f0b68bbe000 ---p 003e2000 08:05 4986836                    /home/henrik/foam/foam-extend-4.0/lib/linux64GccDPOpt/libtetFiniteElement.so
7f0b68bbe000-7f0b68bdd000 r--p 003e1000 08:05 4986836                    /home/henrik/foam/foam-extend-4.0/lib/linux64GccDPOpt/libtetFiniteElement.so
7f0b68bdd000-7f0b68be0000 rw-p 00400000 08:05 4986836                    /home/henrik/foam/foam-extend-4.0/lib/linux64GccDPOpt/libtetFiniteElement.so
7f0b68be0000-7f0b68be9000 rw-p 00000000 00:00 0
7f0b68be9000-7f0b68c0c000 r-xp 00000000 08:05 4986706                    /home/henrik/foam/foam-extend-4.0/lib/linux64GccDPOpt/liblagrangian.so
7f0b68c0c000-7f0b68e0c000 ---p 00023000 08:05 4986706                    /home/henrik/foam/foam-extend-4.0/lib/linux64GccDPOpt/liblagrangian.so
7f0b68e0c000-7f0b68e0d000 r--p 00023000 08:05 4986706                    /home/henrik/foam/foam-extend-4.0/lib/linux64GccDPOpt/liblagrangian.so
7f0b68e0d000-7f0b68e0e000 rw-p 00024000 08:05 4986706                    /home/henrik/foam/foam-extend-4.0/lib/linux64GccDPOpt/liblagrangian.so
7f0b68e0e000-7f0b6920c000 r-xp 00000000 08:05 4982920                    /home/henrik/foam/foam-extend-4.0/lib/linux64GccDPOpt/libfiniteArea.so
7f0b6920c000-7f0b6940b000 ---p 003fe000 08:05 4982920                    /home/henrik/foam/foam-extend-4.0/lib/linux64GccDPOpt/libfiniteArea.so
7f0b6940b000-7f0b69420000 r--p 003fd000 08:05 4982920                    /home/henrik/foam/foam-extend-4.0/lib/linux64GccDPOpt/libfiniteArea.so
7f0b69420000-7f0b69424000 rw-p 00412000 08:05 4982920                    /home/henrik/foam/foam-extend-4.0/lib/linux64GccDPOpt/libfiniteArea.so
7f0b69424000-7f0b6942d000 rw-p 00000000 00:00 0
7f0b6942d000-7f0b6ad78000 r-xp 00000000 08:05 4987874                    /home/henrik/foam/foam-extend-4.0/lib/linux64GccDPOpt/libfiniteVolume.so
7f0b6ad78000-7f0b6af78000 ---p 0194b000 08:05 4987874                    /home/henrik/foam/foam-extend-4.0/lib/linux64GccDPOpt/libfiniteVolume.so
7f0b6af78000-7f0b6affa000 r--p 0194b000 08:05 4987874                    /home/henrik/foam/foam-extend-4.0/lib/linux64GccDPOpt/libfiniteVolume.so
7f0b6affa000-7f0b6b00b000 rw-p 019cd000 08:05 4987874                    /home/henrik/foam/foam-extend-4.0/lib/linux64GccDPOpt/libfiniteVolume.so
7f0b6b00b000-7f0b6b04a000 rw-p 00000000 00:00 0
7f0b6b04a000-7f0b6b2a0000 r-xp 00000000 08:05 4986709                    /home/henrik/foam/foam-extend-4.0/lib/linux64GccDPOpt/libmeshTools.so
7f0b6b2a0000-7f0b6b49f000 ---p 00256000 08:05 4986709                    /home/henrik/foam/foam-extend-4.0/lib/linux64GccDPOpt/libmeshTools.so
7f0b6b49f000-7f0b6b4a5000 r--p 00255000 08:05 4986709                    /home/henrik/foam/foam-extend-4.0/lib/linux64GccDPOpt/libmeshTools.so
7f0b6b4a5000-7f0b6b4a9000 rw-p 0025b000 08:05 4986709                    /home/henrik/foam/foam-extend-4.0/lib/linux64GccDPOpt/libmeshTools.so
7f0b6b4a9000-7f0b6b4ac000 rw-p 00000000 00:00 0
7f0b6b4ac000-7f0b6b4dc000 r-xp 00000000 08:05 4986693                    /home/henrik/foam/foam-extend-4.0/lib/linux64GccDPOpt/libdecompositionMethods.so
7f0b6b4dc000-7f0b6b6dc000 ---p 00030000 08:05 4986693                    /home/henrik/foam/foam-extend-4.0/lib/linux64GccDPOpt/libdecompositionMethods.so
7f0b6b6dc000-7f0b6b6dd000 r--p 00030000 08:05 4986693                    /home/henrik/foam/foam-extend-4.0/lib/linux64GccDPOpt/libdecompositionMethods.so
7f0b6b6dd000-7f0b6b6de000 rw-p 00031000 08:05 4986693                    /home/henrik/foam/foam-extend-4.0/lib/linux64GccDPOpt/libdecompositionMethods.so
7f0b6b6de000-7f0b6b704000 r-xp 00000000 08:05 6820439                    /lib/x86_64-linux-gnu/ld-2.23.so
7f0b6b7e5000-7f0b6b8d7000 rw-p 00000000 00:00 0
7f0b6b8dc000-7f0b6b903000 rw-p 00000000 00:00 0
7f0b6b903000-7f0b6b904000 r--p 00025000 08:05 6820439                    /lib/x86_64-linux-gnu/ld-2.23.so
7f0b6b904000-7f0b6b905000 rw-p 00026000 08:05 6820439                    /lib/x86_64-linux-gnu/ld-2.23.so
7f0b6b905000-7f0b6b906000 rw-p 00000000 00:00 0
7ffdf093c000-7ffdf095f000 rw-p 00000000 00:00 0                          [stack]
7ffdf09ae000-7ffdf09b0000 r--p 00000000 00:00 0                          [vvar]
7ffdf09b0000-7ffdf09b2000 r-xp 00000000 00:00 0                          [vdso]
ffffffffff600000-ffffffffff601000 r-xp 00000000 00:00 0                  [vsyscall]
Aborted (core dumped)
Anyone encountered this before or got some tips of how to solve it?
Here is my project:
https://www.dropbox.com/s/xs22fqbemw...23.tar.gz?dl=0
/ Henrik
HenrikJohansson is offline   Reply With Quote
foam, foam-extend-4.0, mixing plane, mixing plane model
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 03:09
Vertical axis wind turbine - GGI problem Piotr Zwolinski CFX 1 January 12, 2014 07:01
Problem with mixing plane for rotor-stator simulation Frukk FLUENT 0 September 24, 2013 10:47
Total mass flow/flux through a plane problem nwalters FLUENT 1 December 18, 2010 13:23
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found piprus OpenFOAM Installation 22 February 25, 2010 14:43
