How to have spatially varying inlet velocity profile for a multiphase flow
Old   September 28, 2017, 09:27
Default How to have spatially varying inlet velocity profile for a multiphase flow
Ørjan Kvamme
orjankv is on a distinguished road
Hi folks,
Looking for input on how to set a spatially varying inlet velocity for example linear:
U(y) = S*y
The flow is multiphase (air, water), where the water part is the one that needs to have the spatially varying velocity.
Preferably there is also a way to change the initial velocity in the water part as well, maybe by using the setFields utility and topoSet?
orjankv is offline   Reply With Quote
Old   October 4, 2017, 15:44
Thomas Evans
windscion is on a distinguished road
The setFields utility can set cell values and/or face values. What you need here is face values on the inflow patch. This fragment from setFieldsDict should give you the idea.
defaultFieldValues
volVectorFieldValue U (0.4 0 0)
regions
boxToFace
box (-1 -1 -30) (1 1201 -27.5);
fieldValues
volVectorFieldValue U (0.267863 0 0)
boxToFace
box (-1 -1 -27.5) (1 1201 -25);
fieldValues
volVectorFieldValue U (0.313519 0 0)
boxToFace
box (-1 -1 -25) (1 1201 -22.5);
fieldValues
volVectorFieldValue U (0.334759 0 0)
// ... more boxes
Oops, I missed the part where you said ICs as well. Same idea, but use boxToCell with boxes that cover the required volumes. If making the variation smooth is crucial, you probably want to use funkySetFields.
windscion is offline   Reply With Quote
Old   October 5, 2017, 06:42
Ørjan Kvamme
Smooth variation is ideal, so I should try funkySetFields. Do you need to compile something to get funkySetFields to get it. It just says command not found when I try to execute.
I am currently running OpenFoam 5.0.
Old   October 5, 2017, 10:16
Thomas Evans
funkySetFields is part of swak4foam -- https://openfoamwiki.net/index.php/Contrib/swak4Foam
Issues on the simulation of high-speed compressible flow within turbomachinery dowlee OpenFOAM Running, Solving & CFD 11 August 6, 2021 07:40
UDF parbolic inlet velocity profile for 3D Ractangular channel flow. srv537 Fluent UDF and Scheme Programming 4 August 10, 2016 10:25
3D Velocity profile for turbulent flow Kirill Fluent UDF and Scheme Programming 3 July 17, 2014 09:42
How to define a fixed velocity for a given mass flow rate on inlet mqasimali FLUENT 2 April 12, 2013 18:24
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 06:13
