Time Varying Inlet Conditions (Yaw)
Old   August 4, 2017, 11:12
Default Time Varying Inlet Conditions (Yaw)
Stephen
stephen_spicer is on a distinguished road
Hello, I'm new to OpenFOAM. I'm doing work with LES on Yaw angles on a wing. I have set up and run static cases with inflow coming at 5 degrees of yaw.
However I do not know how to do vary the inlet conditions with time, so I want the simulation to start as normal with 0 yaw angle, then over a period of time to change the direction of incoming flow to 5 degrees of yaw. I don't know how to do this.
Using version 2.3.0 as that's the one on the cluster I use
Can anybody help me please?
Regards
Stephen
stephen_spicer is offline   Reply With Quote
Old   August 27, 2017, 03:42
Nima Samkhaniani
nimasam is on a distinguished road
you change the direction of inlet velocity with time using groovyBC fro swak4Foam
My Personal Website (http://nimasamkhaniani.ir/)
Telegram channel (https://t.me/cfd_foam)
nimasam is offline   Reply With Quote
inlet condition, open foam, time varying, wing simulation, yaw
[Other] Contribution a new utility: refine wall layer mesh based on yPlus field lakeat OpenFOAM Community Contributions 58 December 23, 2021 03:36
Time varying boundary conditions tsevine SU2 3 February 2, 2020 22:12
Time varying velocity inlet boundary conditions using TableFile.H pruthvi1991 OpenFOAM Running, Solving & CFD 4 November 4, 2015 01:22
time varying inlet velocity Zhe Liu CFX 0 July 31, 2008 07:56
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 19:07
