[swak4Foam] groovyBC and access to fields of other Regions
Old   July 29, 2017, 09:41
Default groovyBC and access to fields of other Regions
Alejandro
ancolli is on a distinguished road
I am using groovyBC to access to the another region.
If i use as a variable "T{solid_to_fluid/solid}=fim;"; it is working but i am getting an average of fim instead of a local value
 From function ExpressionResult::getUniformInternal(const label size,bool noWarn)
    in file ExpressionResult/ExpressionResultI.H at line 353
    The minimum value 1.859132 and the maximum 5.000479 differ. I will use the average 2.921159;
I tried with mapped variables by reading Examples/test (the cases with "mapped" in the name) as suggested by Bernhard Gschaider
            "fluid_to_.*"
        	type            groovyBC;
		gradientExpression "0";
		fractionExpression "1";
		valueExpression	"T";
		variables "T=mapped(fim);";//"T{solid_to_fluid/solid}=fim;";
		value           $internalField;
But I am getting the following error:
--> FOAM FATAL ERROR:
 Parser Error for driver PatchValueExpressionDriver at "1.8-10" :"field fim not existing or of wrong type"
"mapped(fim)"
It seems that is not recognizing the solid region.
The incomplete swak4foam reference: if the current patch is a mappedpatch and the external expression is evaluated on the “partner patch”. In this case the non-uniform result will be mapped to thelocal patch.
Do u have some hints or tutorial that i can read to solve that problem?
ancolli is offline   Reply With Quote
[swak4Foam] groovyBC and funkySetFields married and got a kid named swak4Foam gschaider OpenFOAM Community Contributions 169 August 10, 2023 10:01
[swak4Foam] access field variables in groovyBC mehtab OpenFOAM Community Contributions 11 February 4, 2019 13:08
[swak4Foam] groovyBC and access to alpha field of other patch Tobi OpenFOAM Community Contributions 4 September 2, 2014 05:04
[swak4Foam] whats the trick to access to second layer of patch neighbors in groovyBC? immortality OpenFOAM Community Contributions 6 July 9, 2013 13:01
[swak4Foam] Can groovyBC access dimensionedScalar? argonaut OpenFOAM Community Contributions 1 May 24, 2012 10:04
