Mapping csv (or other text format) data sets onto volumetric mesh
Old   July 24, 2017, 11:14
Default Mapping csv (or other text format) data sets onto volumetric mesh
Vesselin Krastev
vkrastev is on a distinguished road
Hi all,
my issue is quite straightforward: I need to map a data set (velocity field), which is contained in a csv file, onto an OpenFOAM mesh for flow initialization. The data set is 3D and ordered in columns. I have 3 columns representing the x,y,z coordinates of the nodes where velocities are stored, plus 3 columns representing the x,y,z velocity components. I know how to export data from OF to csv files (through Paraview), but I don't know how to do the opposite. Note that in my case the coordinates contained in the csv file are perfectly conformal to the coordinates of the cell centres in the target mesh. The latter is a simple 64^3 cubic mesh with equally spaced hexahedrons.
Thank you in advance for your help
V.
vkrastev is offline   Reply With Quote
Old   July 24, 2017, 11:25
akidess's Avatar
Anton Kidess
I don't think there's a built-in way. It's fairly straight forward to write your own tool though that reads your input file, finds the corresponding cells (using the convieniently named mesh.findCell function) and sets the value. Your mesh is so small you probably don't even need to worry about parallelization.
*On twitter @akidTwit
*Spend as much time formulating your questions as you expect people to spend on their answer.
Old   July 24, 2017, 12:52
Vesselin Krastev
I was suspecting this, what surprises me is that I've found a relatively low amount of people asking about this (missing) feature around the web...
Can you share some coding example or piece of existing code where this function is applied?
Thanks
V.
Old   July 25, 2017, 05:41
akidess's Avatar
Anton Kidess
I wrote very similar code for my PhD, but it will take a while to dig it up again.
Old   July 25, 2017, 05:52
Vesselin Krastev
Well, if you succeed in digging it up that would be great.
Thanks anyway for your responses.
V.
Old   July 27, 2017, 16:49
akidess's Avatar
Anton Kidess
    for (long row=1; row<=csv_total_rows; row++)
        for(long column=1; column<=csv_total_columns; column++)
            long index = (row-1)*csv_total_columns+column-1;
            scalar xpos = csv_data[index].nodeposition[0];
            scalar ypos = csv_data[index].nodeposition[1];
            scalar zpos = csv_data[index].nodeposition[2];
            vector pos(xpos, ypos, zpos);
            label ofCellLabel = vsf().mesh().findCell(pos);
            vsf[ofCellLabel] = csv_data[index].value();
Where vsf is your volScalarField, and you read and parsed the CSV file by standard C++ methods somewhere else. Easy
Old   July 28, 2017, 14:58
Vesselin Krastev
Ok, thanks.
Old   June 17, 2019, 09:41
Default Where to implement this code?
Wolvi_Tin
kudetisiddhartha is on a distinguished road
Hallo,
I am very new to OpenFoam and c++ coding. I have a similar case like this. Can you please help me on how and where should i implement this in my source code?
Regards
kudetisiddhartha is offline   Reply With Quote
Salome cgns format mesh to SU2 JPBLourenco SU2 19 November 18, 2019 03:11
UDF for Mapping 3D Experimental Data (Heat Generation) to Mesh jbo214 Fluent UDF and Scheme Programming 1 May 15, 2017 16:47
Mapping values from 2D mesh to 3D mesh boundary during runtime benk OpenFOAM Programming & Development 1 June 13, 2014 03:39
Compare two data sets same mesh gregjunqua OpenFOAM Post-Processing 0 February 24, 2014 21:02
Icemcfd 11: Loss of mesh from surface mesh option? Joe CFX 2 March 26, 2007 19:10
