How to set values for specific regions permanently during the simulation
Old   July 23, 2017, 14:24
Default How to set values for specific regions permanently during the simulation
Peter Shi
PeterShi is on a distinguished road
Hello there,
I know setFields can set initial values for the specific regions. However, if I want to set values for specific regions permanently during the simulation, what should I do?
Additionally, could anyone please tell me what does following list mean in setFields? (like what is the meaning of boxToCell?)
boundaryToFace
boxToCell
boxToFace
boxToPoint
cellToCell
cellToFace
cellToPoint
cylinderAnnulusToCell
cylinderToCell
faceToCell
faceToFace
faceToPoint
faceZoneToCell
faceZoneToFaceZone
fieldToCell
labelToCell
labelToFace
labelToPoint
nbrToCell
nearestToCell
nearestToPoint
normalToFace
patchToFace
pointToCell
pointToFace
pointToPoint
regionToCell
rotatedBoxToCell
setToCellZone
setToFaceZone
setToPointZone
setsToFaceZone
shapeToCell
sphereToCell
surfaceToCell
surfaceToPoint
zoneToCell
zoneToFace
zoneToPoint
So many thanks.
Best regards,
Peter
PeterShi is offline   Reply With Quote
Old   July 23, 2017, 16:38
Alexey Matveichev
alexeym has a spectacular aura aboutalexeym has a spectacular aura about
Send a message via Skype™ to alexeym
You can use fixedValueConstraint. Example is in header comment of $FOAM_SRC/fvOptions/constraints/fixedValueConstraint/FixedValueConstraint.H
It is a list of available ways to describe area, where setFields will set fields. boxToCell converts box into set of cells, i.e. select all cells with centres inside a box).
alexeym is offline   Reply With Quote
Old   July 23, 2017, 16:46
Peter Shi
Originally Posted by alexeym View Post
Hello Sir,
Thanks for your reply. So two following points of boxTocell define the limits of that box and determine its corresponding place in the space, right?
Then if my region is irregular, i.e. neither can be described by the box nor the cylinder, what should I do?
I will try the suggested FixedValueConstraint first and see how it works.
So many thanks.
Best regards,
Peter
Old   July 23, 2017, 16:56
Alexey Matveichev
There is surfaceToCell class, which can use arbitrary surface to select cells. Also "irregular" is rather vague word. Up to certain precision irregular region can be presented as a set of boxes.
Old   July 23, 2017, 16:58
Peter Shi
Hello Sir,
Thanks for the help, let me have a try.
Have a nice day.
Best regard,
Peter
Old   July 24, 2017, 13:43
Peter Shi
Hi Sir,
I succeeded with your advice, thank you so much.
Best,
Peter
setfields
Set up air-conditioner simulation tongba99 FLUENT 2 December 23, 2016 11:58
Problem storing values at UDM for tranisient dynamic mesh simulation xab Fluent UDF and Scheme Programming 4 December 22, 2016 05:10
Monitor point values in a steady state simulation Kushagra CFX 2 July 13, 2008 21:03
Numerical values from simulation Ravi FLUENT 0 February 11, 2003 10:02
How to set up a 1-D simulation Olof Liungman Phoenics 1 February 1, 2002 13:06
