Modelling surface tension
Old   July 22, 2017, 01:28
Default Modelling surface tension
Alireza Sheikhi
Alireza_rmc is on a distinguished road
Hello everyone,
I'm modelling water droplets hitting a cylindrical surface using interFoam and then compare it to experimental results.
I was wondering how I can model the surface tension between the droplets and the surface.
I used constantAlphaContactAngle but as expected, it dodnt lead to good results.
Alireza_rmc is offline   Reply With Quote
explicit VOF model- surface tension model srv537 FLUENT 0 July 19, 2016 06:09
How to add Surface Tension in cavitatingFoam solver jamestangx OpenFOAM Programming & Development 1 April 6, 2016 16:39
surface tension gradient using UDF; surface tension gradient as function of temperatu marimuthusundar Fluent UDF and Scheme Programming 0 June 21, 2012 04:48
Surface Tension Test Cases sega OpenFOAM Running, Solving & CFD 2 March 8, 2011 12:19
modeling pipe flow with strong surface tension phsieh2005 OpenFOAM 0 August 27, 2009 13:51
