July 12, 2017, 16:15 |
3D thermal Baffles case set up
Hi all,
I'm trying to model a simple test case using chtMultiRegionSimpleFoam and 3DthermalBaffles. The case is like the 2dplaneWall tutorial, with two fluids keep segregated by a surface between them (name: separationPad). That surface I would like to use as 3D thermal Baffle. I would like to better understand how the final structure of the folders and dictionary should be. Should the constant dir contain a folder for each baffle? or should it be like the circuitBoard tutorial that polyMesh folder contains the 3DBaffles polymesh folder? What are the top,bottom, side patches inside contant/3dBaffleRegion/boundary for circuitBoard tutorial? How can I define a polyMesh folder for the surface with openFoam utilities? Thanks |
3dthermalbaffles |
chtMultiRegionSimpleFoam: Thermal Conduction + Surface-To-Surface Radiation | Zeppo | OpenFOAM Running, Solving & CFD | 16 | May 18, 2017 18:04 |
simpleFoam: case only converges with most div schemes set to upwind | buffi | OpenFOAM Running, Solving & CFD | 7 | November 11, 2013 07:54 |
Env variable not set | gruber2 | OpenFOAM Installation | 5 | December 30, 2005 04:27 |
Thermal modeling of a Al case | Michael Linderman | Main CFD Forum | 3 | July 6, 2001 18:18 |
Info: Short Course On Thermal Design of Electronic Equipment | Arnold Free | Main CFD Forum | 0 | August 10, 1999 10:18 |
