K-Omega SST BC set up for omega and K
Old   July 6, 2017, 18:15
Default K-Omega SST BC set up for omega and K
Joseph O'Neill
joneill053 is on a distinguished road
Hi All,
I am attempting to set up a 2-D case for a NACA 4318 airfoil using HELYX-OS and OpenFOAM in an attempt to simply match data from both accepted NACA data and other CFD software, namely GHOST and STAR-CCM+.
I have managed to do this well using the Spallart-Allmaras model. My very basic setup (I have only been using OpenFOAM for just over a month) to begin with was a simple non-slip wall over the airfoil and slip walls at all other boundary conditions with uniform inlet velocity being approximately 23.45 m/s with a zero pressure gradient at the inlet and a zero gradient velocity and fixed value of 0 for pressure at the outlet. Using SA, these conditions worked relatively well for matching Cl and Cp (drag was still a bit off).
I have tried similar boundary conditions for the K-Omega SST model, and yield absurdly large values for both Cl and Cd so I'm fairly certain I'm mixed up on how to set up my boundary conditions for K-Omega SST with respect to OpenFOAM.
Could anyone help guide me along for a proper set up for the K-Omega SST model BC's? And help at all would be much appreciated! I'm currently paging through a few tutorials given by OpenFOAM to diagnose the issue, but again I am relatively new to this software and CFD as a whole so I'm not quite sure where to begin.
Regards,
Joe
joneill053 is offline   Reply With Quote
Old   July 10, 2017, 13:20
Joshua
Joshua14 is on a distinguished road
This is an older post, so I am not sure how much has changed, but it is worth looking through.
Why Menter's SST model low-Re issue has not been seriously investigated?
There are also this post on CFD Online.
Near wall treatment in k-omega SST
Joshua14 is offline   Reply With Quote
Old   July 10, 2017, 15:29
Joseph O'Neill
Josh,
Thanks! I'll give these a look through and try to implement what I find and I'll let you know what I cycle through and find out.
Best,
Joe
k and omega at inlet for k-omega SST driu OpenFOAM Running, Solving & CFD 10 March 5, 2021 11:48
Instalation on ubuntu 710 basilwatson OpenFOAM Installation 17 March 16, 2012 21:16
How to show the transient case? H.P.LIU Phoenics 7 July 13, 2010 05:31
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found piprus OpenFOAM Installation 22 February 25, 2010 14:43
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 20:08
