Using same grid for different attack angles
Old   July 4, 2017, 15:02
Default Using same grid for different attack angles
gereksiz
clktp is on a distinguished road
I have a geometry and I wanna obtain pressure on its surfaces for flow directions. Well you can think like different attack angles, it is not an airfoil though. The problem is I wanna use the same grid without generating grid every time but I have no idea how to do if it is possible of course.
Can I use a interface or something else to do it? I was wondering maybe there is a way to do it in a similar way to rotating axis approach. In my case nothings rotates obviously.
clktp is offline   Reply With Quote
Old   July 5, 2017, 04:14
Tom Fahner
tomf will become famous soon enoughtomf will become famous soon enough
Send a message via MSN to tomf Send a message via Skype™ to tomf
You can, it can be done either using a circular domain or using a rectangular domain. We typically use a circular domain for wind studies with multiple directions and then use groovyBC to set an atmospheric boundary layer outlet/inlet boundary condition where the behavior of the domain boundary condition depends on the angle specified in the groovyBC variables.
Something like this:
    Domain
        type            groovyBC;
        value           $internalField;
        valueExpression "vector(sin(alpha*pi/180),cos(alpha*pi/180),0)*Uvalue";
        gradientExpression "vector(0,0,0)";
        fractionExpression "(phi > 0 ) ? 0 : 1";
        variables       "Uvalue=5;alpha=74.50;";
Best regards,
Tom
tomf is offline   Reply With Quote
Grid Check Script pdp.aero SU2 2 April 23, 2015 01:54
High Lift Airfoils At High Angles Of Attack Luiz Pancini FLUENT 2 April 9, 2015 08:01
Need Cl,Cd for high angles of attack Poojitha FLUENT 2 October 24, 2013 00:01
Grid Adaptation Suresh FLUENT 0 October 15, 2003 13:18
GRID TO GRID INTERPOLATION in FLUENT calogero FLUENT 3 June 4, 2003 08:32
