moving rotor AMI
Old   July 2, 2017, 10:49
Default moving rotor AMI
the_edge123 is on a distinguished road
New to OF, I successfully ran this tutorial [1] with minor modifications for OpenFOAM-v1612+.
Now, I'm trying to build a similar case using my propeller instead of the rotor. My first goal is to check the moving mesh.
If I use the following parameters in sHM, createPatch gives result1_AMI containing result1_movingWall. The AMI is incorrect, which is normal.
castellatedMeshControls
maxLocalCells 24000;
maxGlobalCells 48000;
If I slightly increase the values, createPatch gives result2. The AMI seems correct but my propeller disappeared.
maxLocalCells 24375;
maxGlobalCells 48750;
Did I miss something ?
Fabien
[1] http://www.holzmann-cfd.de/index.php...ving-rotor-ami
the_edge123 is offline   Reply With Quote
Old   July 12, 2017, 06:45
The problem did not come from createPatch but from the STL given to sHM.
I rebuilt the propeller in salome.
Next step is to refine the propeller.
Force magnitude with moving mesh fernexda OpenFOAM Post-Processing 3 April 12, 2016 09:09
Question on moving mesh, mesh velocity is really small! ripperjack Main CFD Forum 2 April 28, 2014 13:37
[snappyHexMesh] jagged, ragged edges... ziemowitzima OpenFOAM Meshing & Mesh Conversion 138 July 23, 2012 23:41
[Other] How to set up a dynamic mesh for a piston moving through a tube of variable diameter? karkar OpenFOAM Meshing & Mesh Conversion 0 July 4, 2012 06:54
Moving mesh in Fluent fivos FLUENT 0 April 2, 2010 09:45
