Blender: generate stl files
Old   June 6, 2017, 03:45
Default Blender: generate stl files
M. C.
student666 is on a distinguished road
I use Salome to generate stl files for meshing, but when it comes to redefine them (e.g. separate a stl into more stl files), it's not so simple and generally you have to redefine all.
What I mean is that I would like to perform following steps, taking as example a 2D planar rectangular face:
  1. define inside the rectangular a circle belonging to same plane of the first
  2. define a proper edge size for the edge circle
  3. trinagulate separately the two meshes
  4. export them as stl files
How should I do this with Blender?
Thanks a lot for any suggestion
student666 is offline   Reply With Quote
[snappyHexMesh] Best way to create inlet/outlet out of STL files? JR22 OpenFOAM Meshing & Mesh Conversion 1 February 26, 2013 00:49
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found piprus OpenFOAM Installation 22 February 25, 2010 14:43
Problems in compiling paraview in Suse 10.3 platform chiven OpenFOAM Installation 3 December 1, 2009 08:21
OpenFOAM15 paraFoam bug koen OpenFOAM Bugs 19 June 30, 2009 11:46
Results saving in CFD hawk Main CFD Forum 16 July 21, 2005 21:51
