May 23, 2017, 22:18 |
compressibleInterFoam p and U BCS
cherry
I have used the totalPressure for P inlet, fixedValue for P outlet and PressureInletoutletvelocity for U inlet and inletOut for U outlet. But the solution shows that the maximum velocity in the field continuously decreases and eventually the minimum pressure continuously increasing. I have tried other BCs combination, but they don't work. Could someone give any suggestion on the BCs for commpressble two-phase flows?
compressibleinterfoam bcs |
How to set BCs programmatically | incompressible | OpenFOAM Programming & Development | 6 | November 20, 2017 03:47 |
chtMultiRegionSimpleFoam: inconsistency between BCs and results | Diro7 | OpenFOAM Running, Solving & CFD | 1 | March 2, 2017 05:36 |
Difference between HF and Temperature BCs | Catthan | FLUENT | 0 | August 7, 2013 06:59 |
Dealing with BC's in OF 1.6 | vkrastev | OpenFOAM Running, Solving & CFD | 5 | September 4, 2012 12:58 |
Understanding Code behind BCs | Linse | OpenFOAM Programming & Development | 8 | January 9, 2012 09:58 |
