Case set-up: conjugate heat-transfer in 3D metallic foam |
May 22, 2017, 06:42 |
Marc
Rep Power: 9 |
This is my first thread in this forum and I would like some guidance about my first serious OpenFOAM project and how to set-up the case. As the title suggests, I'm aiming to model conjugate heat transfer across a metallic foam heat exchanger whose geometry looks something like this: My issues with this case are the following:
In a more general sense, what I am looking for is guidance into how to set-up the case in order to obtain meaningful results coming from the perspective of a user with little experience. Thank you in advance! |
June 3, 2017, 06:23 |
Marc
Rep Power: 9 |
Help in any of the different sections in which I have posed questions would be greatly appreciated
boundary conditions, chtmultiregionsimplefoam, conjugate heat transfer, snappyhexmesh |
Set heat transfer as default for interfaces | edward.pocock | CFX | 3 | November 20, 2014 12:37 |
Test case: Conjugate Heat Transfer | skapetan | Main CFD Forum | 2 | November 9, 2014 05:45 |
Conjugate heat transfer | kiteguru | CFX | 2 | January 9, 2012 16:57 |
Heat Flux at wall in a conjugate heat transfer problem | Chander | CFX | 2 | July 9, 2011 23:22 |
[blockMesh] BlockMesh FOAM warning | gaottino | OpenFOAM Meshing & Mesh Conversion | 7 | July 19, 2010 15:11 |
