Unknown patchfieldtype fixedFluxPressure for patch type patch
Old   May 18, 2017, 11:32
Default Unknown patchfieldtype fixedFluxPressure for patch type patch
CFDLover9001 is on a distinguished road
Apologies if this is in the wrong subforum, I didn't know whether it belonged here or in the running/solving subforum.
I have a problem when I run the command interFoam. During its reading of my U file I get the following error: 'Unknown patchfieldtype fixedFluxPressure for patch type patch'. Along with that I get a list of patchfield types that are available. However I have no idea which of these I am supposted to choose instead.
I'm not really experienced with openFoam. What I want is to have an inlet where I can define a velocity(or velocity vector) for where a fluid comes in. From my understanding an inlet should be of type patch, and using http://www.openfoam.com/documentatio...conditions.php I gathered that fixedFluxPressure for the inlet seemed to be the fieldpatch type I wanted, but it appears I cannot have this.
Does anyone have an idea what fieldpatch type I should be using to be able to define an inlet velocity?
Here is the U file incase you want to see it. I'm attempting to modify the "tutorials/multiphase/interfoam/angleDuct" tutorial.
|  \\    /   O peration     | Version:  2.3.x                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      ascii;
    class       volVectorField;
    object      U;
dimensions      [0 1 -1 0 0 0 0];
internalField   uniform (0 0 0);
boundaryField
    walls
        type            fixedValue;
        value           uniform (0 0 0);
    inlet
        type            fixedFluxPressure;
        value           uniform (1 0 0);
    outlet
        type            pressureInletOutletVelocity;
        inletValue      uniform (0 0 0);
CFDLover9001 is offline   Reply With Quote
rhoPimpleFoam hardship petrus OpenFOAM Running, Solving & CFD 0 October 7, 2016 03:41
Modified pimpleFoam solver to MRFPimpleFoam solver hiuluom OpenFOAM Programming & Development 12 June 14, 2015 22:22
Possible Bug in pimpleFoam (or createPatch) (or fluent3DMeshToFoam) cfdonline2mohsen OpenFOAM 3 October 21, 2013 10:28
[GAMBIT] periodic faces not matching Aadhavan ANSYS Meshing & Geometry 6 August 31, 2013 12:25
compressible two phase flow in CFX4.4 youngan CFX 0 July 2, 2003 00:32
