Problem with decomposing case with cyclicAMI
Old   April 24, 2017, 06:34
Default Problem with decomposing case with cyclicAMI
Jan Surwiło
johny0688 is on a distinguished road
I tried to calculate case with translational periodic. I use cyclicAMI with translation. It works fine for serial run. But in parallel the error occurred and calculation can't be start. While mesh checking only the error for nonorthogonal in few cells but generally mesh is good. There is no error during decomposing.
I changed cyclicAMI for slipWall, now there is no problem with parallel run.
How to decompose case with cyclic BC? Is it possible in openFoam?
johny0688 is offline   Reply With Quote
Old   June 27, 2017, 17:31
Sugajen
Sugajen is on a distinguished road
Hey Jan,
Were you able to fix the issue? I am facing the same problem with simpleFoam and cyclicAMI. I addded lines in decomposeParDict to preservePatches too. But doesn't seems to help.
Thanks,
Sugajen
Sugajen is offline   Reply With Quote
Old   January 8, 2018, 10:09
Q.E.D. is on a distinguished road
Hello both of you,
maybe the reply is a bit late, but I was recently facing a similiar problem.
The solution described in this post worked fine for me: Running AMI case in parallel
Best wishes,
Q.E.D.
Q.E.D. is offline   Reply With Quote
cyclicami, decomposed, parralel
Pressure instabilities with interDyMFoam for the floatingObject case nbadano OpenFOAM Running, Solving & CFD 15 October 15, 2021 07:35
Problem to run flow around a cylinder - LES case valerio galluzzi OpenFOAM Pre-Processing 2 August 29, 2014 06:05
Problem to run flow around a cylinder - LES case valerio galluzzi OpenFOAM Pre-Processing 0 August 26, 2014 08:47
Problem in unstructured circular cylinder case Tarak OpenFOAM Running, Solving & CFD 3 January 5, 2011 04:13
case example for HVAC problem kevin FLUENT 0 April 3, 2004 13:09
