Difference between dynamicMeshDict - dynamicMeshDict.sixDoF |
April 19, 2017, 10:51 |
Marc Batlle
Rep Power: 9 |
Hello everyone,
Now a days I am working on a "Floating Object" exercise and I found my self in trouble to understand the difference between dynamicMeshDict - dynamicMeshDict.sixDoF. My C+ knowledge is quite limited so I prefer not to get deep on the scripts. At first, in the easy way I tried to run the tutorial exercise using first the dynamicMeshDict as it comes per default and then deleting it, and using the "dynamicMeshDict.sixDoF" file with the new name "dynamicMeshDict". But when I run it, I get the next message in the "log.interDyMFoam" file: --> FOAM FATAL IO ERROR: keyword centreOfMass is undefined in dictionary "/home/batllemm/OpenFOAM/batllemm-4.1/run/6DOF/floatingObject.3D.1/constant/dynamicMeshDict.sixDoFRigidBodyMotionCoeffs" file: /home/batllemm/OpenFOAM/batllemm-4.1/run/6DOF/floatingObject.3D.1/constant/dynamicMeshDict.sixDoFRigidBodyMotionCoeffs from line 25 to line 95. From function const Foam::entry& Foam::dictionary::lookupEntry(const Foam::word&, bool, bool) const in file db/dictionary/dictionary.C at line 441. FOAM exiting Thank you for your help, and good luck Marc |
August 16, 2017, 11:50 |
Rep Power: 10 |
See this document (section 2.1):
https://www.google.de/url?sa=t&rct=j...FqMJDk9g_HGuTw And the release notes of OpenFOAM 4.0: https://openfoam.org/release/4-0/ |
dynamicmeshdict, dynamicmeshdict.sixdof |
I can't understand the moving function of "libfvMotionSolver.so" in dynamicMeshDict | Jung hoo | OpenFOAM Programming & Development | 0 | July 13, 2016 03:36 |
[snappyHexMesh] snappyHexMesh and cyclic boundaries | Ruli | OpenFOAM Meshing & Mesh Conversion | 2 | December 9, 2013 06:51 |
[General] paraview - plotting difference to reference data | joewe | ParaView | 0 | August 30, 2010 18:01 |
the effect of upwind difference | hades | Main CFD Forum | 8 | March 14, 2009 23:43 |
Difference between scaled residuals and... | Dieter | FLUENT | 0 | April 28, 2006 17:52 |
