April 12, 2017, 19:31 |
blueCFD-Core: scotch Method decomposition
I've just downloaded BlueCFD-Core. I'm facing a trivial problem. When I have to decompose my mesh, I have to set scotch as for decomposition method. When I run snappyHexMesh I have to change to ptscotch method, otherwise snappyHexMesh.exe complains as it does not recognize that. Is it possible to fix this? Thanks a lot. |
December 31, 2017, 15:16 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Late/quick answer: See this comment: https://bugs.openfoam.org/view.php?id=2275#c6938
Edit: Or simply let me quote myself from there: Code:
Rough outline: In "decomposeParDict": #include "decompositionMethodDict" In "decompositionMethodDict": method scotch; In the script: echo "method scotch;" > system/decompositionMethodDict #... echo "method ptscotch;" > system/decompositionMethodDict Last edited by wyldckat; December 31, 2017 at 15:17. Reason: see "Edit:" |
[OpenFOAM.org] Install OpenFOAM 2.4.x using system Scotch | cbcoutinho | OpenFOAM Installation | 7 | October 16, 2019 20:12 |
Parallel decomposition | koscfd | OpenFOAM Running, Solving & CFD | 0 | November 2, 2016 12:07 |
Drag Decomposition Method | shivakumar | Main CFD Forum | 0 | January 19, 2015 07:14 |
fluid flow but temperature raises from nowhere? | mxcfd | STAR-CCM+ | 5 | September 16, 2014 06:46 |
Gambit HEX core method gives unwanted 2D region | KK | FLUENT | 1 | February 4, 2008 10:31 |
