[FATAL ERROR] patchSummary : size *** is not equal to the given value of ***
Old   March 29, 2017, 05:28
Default [FATAL ERROR] patchSummary : size *** is not equal to the given value of ***
Clément D.
clemd is on a distinguished road
Hi everyone,
I am trying to run a parallel case with snappyHexMesh and simpleFoam relying on the motorBike tutorial, and I am facing some difficulties. In the system folder, I adapted the blockMeshDict to edit my limit box, the snappyHexMeshDict to refine as I wish and the controlDict. I also adapted the boundary conditions in the 0.org according to the constant/polymesh/boundary file.I have my .stl file in the constant/triSurface/ directory so I follow the steps I found in the Allrun script as below:
surfaceFeatureExtract
blockMesh
decomposePar
mpirun -np 4 snappyHexMesh -parallel -overwrite
ls -d processor* | xargs -I {} rm -rf ./{}/0
ls -d processor* | xargs -I {} cp -r 0.org ./{}/0
Up to this step, everything seems ok, but when I run
mpirun -np 4 patchSummary -parallel
I run into a series of errors like this one :
M FATAL IO ERROR:
[1] size 1651 is not equal to the given value of 853
[1]
[1] file: ***[CASE DIRECTORY]***/processor1/0/thickness.boundaryField.naca_PART_1_FACE from line 56 to line 57.
[1]
[1]     From function Field<Type>::Field(const word& keyword, const dictionary&, const label)
[1]     in file /mnt/home/SW/CFDSupportFOAM4.0/OpenFOAM-3.0.x/src/OpenFOAM/lnInclude/Field.C at line 283.
[1]
FOAM parallel run exiting
and I have the following log :
[[13386,1],2]: A high-performance Open MPI point-to-point messaging module
was unable to find any relevant network interfaces:
Module: OpenFabrics (openib)
  Host: master
Another transport will be used instead, although this may result in
lower performance.
|  \\    /   O peration     | Version:  3.0.x                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
Build  : 3.0.x-4b5e129783d9
Exec   : patchSummary -parallel
Date   : Mar 29 2017
Time   : 10:11:42
Host   : "master"
PID    : 28391
Case   : ***[CASE DIRECTORY]***
nProcs : 4
Slaves :
3
"master.28392"
"master.28393"
"master.28394"
Pstream initialized with:
    floatTransfer      : 0
    nProcsSimpleSum    : 0
    commsType          : nonBlocking
    polling iterations : 0
allowSystemOperations : Allowing user-supplied system call operations
Create time
Create mesh for time = 0
Time = 0
Valid fields:
MPI_ABORT was invoked on rank 2 in communicator MPI_COMM_WORLD
with errorcode 1.
NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
You may or may not see output from other processes, depending on
exactly when Open MPI kills them.
Hoping that someone can help !
Cheers,
Clément
clemd is offline   Reply With Quote
Old   March 20, 2018, 06:50
alix cattermole
alixcattermole is on a distinguished road
Were you even able to resolve this problem and if so how did you do it? As I am trying something similar and getting the same issues and errors.
Thanks.
alixcattermole is offline   Reply With Quote
Old   March 21, 2018, 02:39
Antimony is on a distinguished road
Before generating blockMesh, have you made sure to delete all the previous mesh information?
Typically the "size ** not equal to size ***" comes about because it has two different sources of information, often the result of remeshing without completely wiping out the previous mesh....
Hope this helps.
Cheers,
Antimony
Antimony is offline   Reply With Quote
motorbike, parallel, patchsummary, size, snappyhexmesh
Number of cells in mesh does not equal size of cell Level pizzaspinate OpenFOAM 4 September 27, 2018 01:47
Error size 400 is not equal to the given value of 1681 alimansouri OpenFOAM Running, Solving & CFD 8 August 7, 2018 08:26
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 06:36
[snappyHexMesh] error: Cells in mesh does not equal to size of cell level izna OpenFOAM Meshing & Mesh Conversion 0 July 31, 2013 04:24
FOAM FATAL IO ERROR size 1 is not equal to the given value of 26776 hariya03 OpenFOAM Pre-Processing 3 June 14, 2013 03:11
