Linear periodic?
Old   March 23, 2017, 05:53
Default Linear periodic?
Jan Surwiło
johny0688 is on a distinguished road
My case is typical translational periodic flow. I found cycle, wedge etc. BC but I didn't find straight translational periodic. I use symmetry instead but I do not know if it is right? What is appropriate foam boundary for linear periodic and how to set it.
Thanks in advance,
BTW
I tried to run rhoSimpleFoam wit k-w SST turbulence, air perfect gas. I get the error at the begginning without any iteration. When I change the innitial condition ("0") it can do 2 to 4 iteration and k,omega and time residuals go extremaly high like e+15. Howewer as it iterate I gues the problem is in "0" not in solver setings. The bad is that I did the same calculation in Fluent end seting the foam BC with results from Fluent. This isn't first simulation with rhoSimpleFoam I have problem with. Do you have any advice or strategy for compressible SIMPLE solver with SST turbulence?
Johny
Okey I solved the periodic problem. But still it is impossible to make solver calculating. What are the best boundary condition for k and omega at inlet and outlet?
johny0688 is offline   Reply With Quote
periodic, rhosimplefoam, sst k-omega
2nd Order Convergence Problem for 3D Airfoil turkmengokce OpenFOAM Running, Solving & CFD 1 September 10, 2015 08:20
A turbulent test case for rhoCentralFoam immortality OpenFOAM Running, Solving & CFD 13 April 20, 2014 07:32
suitable boundary condition for scavenging process? immortality OpenFOAM Running, Solving & CFD 3 January 25, 2013 20:10
how to modify fvScheme to converge? immortality OpenFOAM Running, Solving & CFD 15 January 16, 2013 14:06
solution diverges when linear upwind interpolation scheme is used subash OpenFOAM 0 May 29, 2010 02:23
