k-omega SST - Low Re Wall Functions
Old   March 7, 2017, 14:18
Smile k-omega SST - Low Re Wall Functions
Fredi Cenci
fredicenci is on a distinguished road
Hello Guys,
Well, I’ve been reading about the use of wall functions (or not to use them) in k-omega SST.
What I would like to know is:
What is the difference between fixedValue and low reynolds wall funcions (kLowReWallFunction; omegaWallFunction; nutLowReWallFunction)
If I have a external turbulent flow, where y +< 1, and I want to avoid the use of wall functions, what should I use on the walls for k, omega and nut? fixedValue or LowReFunctions?
Also, on "Value" I always set as $internalField (the same value estimated for the inlet). What is the difference if I set "uniform 0" instead internalField ?
Thanks a lot
fredicenci is offline   Reply With Quote
Old   March 7, 2017, 14:36
piu58's Avatar
Uwe Pilz
piu58 is on a distinguished road
If y+ is very small you don't need any wall functions. They don't have any effect, the parameters come close to zero. You may try that out.
Uwe Pilz
Die der Hauptbewegung überlagerte Schwankungsbewegung ist in ihren Einzelheiten so hoffnungslos kompliziert, daß ihre theoretische Berechnung aussichtslos erscheint. (Hermann Schlichting, 1950)
piu58 is offline   Reply With Quote
Old   March 8, 2017, 18:24
Fredi Cenci
Thanks for your reply,
So, what should be the settings for omega and k on the walls? fixedvalue value; uniform 0; ?? zerogradient??
Thanks a lot!
Old   March 9, 2017, 03:17
piu58's Avatar
Uwe Pilz
You may use the adequate wall functions with "uniform 0".
Uwe Pilz
One more time: wall functions - SST CellZone OpenFOAM Pre-Processing 22 June 11, 2021 14:27
Wall functions - questions about implementation AlmostSurelyRob OpenFOAM Programming & Development 44 May 6, 2020 11:11
Wall functions ivan-s Main CFD Forum 0 August 25, 2014 13:35
Boundary Conditions for k omega SST dancfd OpenFOAM Pre-Processing 0 June 10, 2011 00:25
Wall function implementation K Omega SSt cbarry OpenFOAM 3 August 18, 2009 11:09
