Open questions about thermal baffles
Old   March 2, 2017, 01:18
Default Open questions about thermal baffles
M. C.
student666 is on a distinguished road
Thermal baffles are useful to save meshing and computational time during pre-processing and solving, when you have heat transfer problems.
Let’s say I have a domain of 1x1x1 meters.
Inside I put a thin wall (thermalbaffles) to split the domain into two separated regions.
Let’s say this thin wall is a pipe of 1m length.
Two cases:
1 – pipe has outside diameter of 0.4m and 0.1m thickness.
2 – pipe has outside diameter of 0.4m and 0.005m thickness.
Would it possible for both cases to use thermalBaffles strategy for meshing? Or thin walls requires to keep a minimum ratio within dimensions?
In my example above, ratio between outside diameter of pipe and thickness are:
1 – 0.4m/0.1m = 4
2 – 0.4m /0.005m =80
These are extreme cases, just for example to understand.
I suppose that for case 1, if I want to analyze gradient of temperature inside the pipe thickness, it would be better to mesh this region separately. Is it the main and only difference?Are there any other points I have to care about, when I have to prepare my mesh?Are there computational limits on thin wall usage?
Regards.
student666 is offline   Reply With Quote
wmake compiling new solver mksca OpenFOAM Programming & Development 14 June 22, 2018 07:29
SparceImage v1.7.x Issue on MAC OS X rcarmi OpenFOAM Installation 4 August 14, 2014 07:42
OpenFOAM 1.6.x - CentOS 5.3 x86_64 linnemann OpenFOAM Installation 68 April 22, 2013 12:03
openfoam 1.6 on debian etch romant OpenFOAM Installation 9 May 6, 2010 03:26
Info: Short Course On Thermal Design of Electronic Equipment Arnold Free Main CFD Forum 0 August 10, 1999 11:18
