Creating a Velocity Profile at Inlet
Old   February 28, 2017, 06:03
Default Creating a Velocity Profile at Inlet
sjb94 is on a distinguished road
I am relatively new to openFOAM and and under rather tight time constraints (university project). I wish to model the flow around a single pier in a flume that is 10m long. To try and reduce running time I want to reduce the length of the flume in front of the pier.
I have read that if I run the simulation without the pier geometry I can get a velocity profile for the water in the flume at any point (I want it just in front of the leading edge of the pier). I can then extract this profile, put my pier geometry into the mesh and use the velocity profile as the inlet boundary conditions?
Is this possible in openFOAM and is it feasible?
Stu
sjb94 is offline   Reply With Quote
Old   March 1, 2017, 07:47
RK_Token
RK_Token is on a distinguished road
Stu
Hey,
Ich don't know how exactly to do it. But I know that you could peform a simple Channel flow, long enought to geht your Profile. Then use the Outlet (Patch) Profile and set it as your inlet condition oft your Project.
Hope it gives you a hint...
Sent from my ONEPLUS A3003 using CFD Online Forum mobile app
RK_Token is offline   Reply With Quote
Old   March 1, 2017, 12:50
Thank you both
cfd, inlet conditions, velocity profile
UDF for inlet velocity profile Bollonga Fluent UDF and Scheme Programming 4 June 29, 2021 05:40
Define periodic velocity profile by field function at the inlet uhlondon STAR-CCM+ 4 June 24, 2017 05:07
[swak4Foam] Inlet velocity profile for turbulent pipe flow using swak4Foam zordiack OpenFOAM Community Contributions 5 February 23, 2016 02:52
Export & Import Velocity profile as Inlet eRzBeNgEl STAR-CCM+ 6 March 26, 2012 06:16
Inlet Velocity Profile BC - Floating Point exception during solution initialization Janshi STAR-CCM+ 4 March 14, 2012 11:21
