rhoSimpleFoam error
Old   February 17, 2017, 10:01
Default rhoSimpleFoam error
Jan Surwiło
johny0688 is on a distinguished road
I'm new in openFoam. I did the icoFoam and simpleFoam simulation. But now I want to try rhoSimpleFoam with k-e turbulent model and i face problem. Mu case is simple 2,5D cylinder in channel. Velocity inlet v=2m/s on left, pressure outlet p=0Pa on right. Up and down as wall and front/back as empty. I copy the tutorial files from /tutorials/compressible/rhoSimpleFoam/squareBend/. I changed the /0 to my boundary condition and try to run simulate. Byt at the beginning of the calculation I obtain error. I pass my BC below as well as error.
boundary
|  \\    /   O peration     | Version:  4.1                                   |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      ascii;
    class       polyBoundaryMesh;
    location    "constant/polyMesh";
    object      boundary;
6
    cylinder
        type            wall;
        inGroups        1(wall);
        nFaces          188;
        startFace       33632;
    up_wall
        type            wall;
        inGroups        1(wall);
        nFaces          64;
        startFace       33820;
    down_wall
        type            wall;
        inGroups        1(wall);
        nFaces          64;
        startFace       33884;
    inlet
        type            patch;
        nFaces          31;
        startFace       33948;
    outlet
        type            patch;
        nFaces          77;
        startFace       33979;
    front_back_empty
        type            empty;
    //    inGroups        1(wall);
        nFaces          33844;
        startFace       34056;
alphat
FoamFile
    version     2.0;
    format      ascii;
    class       volScalarField;
    location    "0";
    object      alphat;
dimensions      [1 -1 -1 0 0 0 0];
internalField   uniform 0;
boundaryField
    cylinder
            type    compressible::alphatWallFunction;
            Prt    0.85;
            value    uniform 0;
    up_wall
            Prt    0.85;
            value    uniform 0;
    down_wall
            Prt    0.85;
            value    uniform 0;
    inlet
            type    calculated;
            value    uniform 0;
    outlet
            type    calculated;
            value    uniform 0;
    front_back_empty
            type    empty;
k
FoamFile
    version     2.0;
    format      ascii;
    location    "0";
    object      k;
dimensions      [0 2 -2 0 0 0 0];
internalField   uniform 0.0006;
boundaryField
    cylinder
            type    kqRWallFunction;
            value    uniform 0;
    up_wall
            value    uniform 0;
    down_wall
            value    uniform 0;
    inlet
            type    fixedValue;
            value    uniform 0.0006;
    outlet
            type    fixedValue;
    front_back_empty
            type    empty;
epsilon
FoamFile
    version     2.0;
    format      ascii;
    location    "0";
    object      epsilon;
dimensions      [0 2 -3 0 0 0 0];
internalField   uniform 0.0001207;
boundaryField
    cylinder
        type            epsilonWallFunction;
        Cmu             0.09;
        kappa           0.41;
        E               9.8;
        value           uniform 0.0001207;
    up_wall
            Cmu             0.09;
            kappa           0.41;
            E               9.8;
    down_wall
            Cmu             0.09;
            kappa           0.41;
            E               9.8;
    inlet
        type            turbulentMixingLengthDissipationRateInlet;
        mixingLength    0.02;
    outlet
        type            inletOutlet;
        inletValue      uniform 0.0001207;
    front_back_empty
        type    empty
nut
FoamFile
    version     2.0;
    format      ascii;
    location    "0";
    object      nut;
dimensions      [0 2 -1 0 0 0 0];
boundaryField
    cylinder
        type            nutkWallFunction;
        Cmu             0.09;
        kappa           0.41;
        E               9.8;
    up_wall
        type            nutWallFunction;
            Cmu             0.09;
            kappa           0.41;
            E               9.8;
    down_wall
            Cmu             0.09;
            kappa           0.41;
            E               9.8;
    inlet
    type    calculated;
    value    uniform 0;
    outlet
        type    calculated;
        value    uniform    0;
    front_back_empty
        type    empty
p
FoamFile
    version     2.0;
    format      ascii;
    object      p;
dimensions      [1 -1 -2 0 0 0 0];
boundaryField
    "(cylinder|up_wall|down_wall)"
        type            zeroGradient;
    inlet
        type            zeroGradient;
        //type            mixed;
        refValue        uniform ;
        refGradient     uniform 0;
        valueFraction   uniform 0;
    outlet
        type            fixedValue;
        value           uniform 110000;
        //type            mixed;
        //refValue        uniform 110000;
        //refGradient     uniform 0;
        //valueFraction   uniform 1;
        //type            transonicOutletPressure;
        //U               U;
        //phi             phi;
        //gamma           1.4;
        //psi             psi;
        //pInf            uniform 110000;
    front_back_empty
        type    empty;
T
FoamFile
    version     2.0;
    format      ascii;
    object      T;
dimensions      [0 0 0 1 0 0 0];
internalField   uniform 300;
boundaryField
        type            zeroGradient;
    inlet
        type            fixedValue;
        value           uniform 300;
    outlet
        type            inletOutlet;
        //type            zeroGradient;
        value           uniform 300;
        inletValue      uniform 300;
    front_back_empty
        type    empty;
U
FoamFile
    version     2.0;
    format      ascii;
    class       volVectorField;
    object      U;
dimensions      [0 1 -1 0 0 0 0];
internalField   uniform (0 0 0);
boundaryField
        type            noSlip;
    inlet
        type            fixedValue;
        value        uniform (2 0 0);
    outlet
        type            zeroGradient;
    front_back_empty
        type    empty;
error
Build  : 4.1
Exec   : rhoSimpleFoam
Date   : Feb 17 2017
Time   : 14:35:44
Host   : "jan-VirtualBox"
PID    : 11498
Case   : /home/jan/open_test/cylinder_rho_simple
nProcs : 1
allowSystemOperations : Allowing user-supplied system call operations
Create time
Create mesh for time = 0
SIMPLE: convergence criteria
    field p     tolerance 0.001
    field U     tolerance 0.0001
    field e     tolerance 0.001
    field "(k|epsilon|omega)"     tolerance 0.001
Reading thermophysical properties
Selecting thermodynamics package
    type            hePsiThermo;
    mixture         pureMixture;
    transport       sutherland;
    thermo          hConst;
    equationOfState perfectGas;
    specie          specie;
    energy          sensibleInternalEnergy;
#0  Foam::error::printStack(Foam::Ostream&) at ??:?
#1  Foam::sigFpe::sigHandler(int) at ??:?
#2  ? in "/lib/x86_64-linux-gnu/libc.so.6"
#3  Foam::heThermo<Foam::psiThermo, Foam::pureMixture<Foam::sutherlandTransport<Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleInternalEnergy> > > >::heThermo(Foam::fvMesh const&, Foam::word const&) at ??:?
#4  Foam::psiThermo::addfvMeshConstructorToTable<Foam::hePsiThermo<Foam::psiThermo, Foam::pureMixture<Foam::sutherlandTransport<Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleInternalEnergy> > > > >::New(Foam::fvMesh const&, Foam::word const&) at ??:?
#5  Foam::autoPtr<Foam::psiThermo> Foam::basicThermo::New<Foam::psiThermo>(Foam::fvMesh const&, Foam::word const&) at ??:?
#6  Foam::psiThermo::New(Foam::fvMesh const&, Foam::word const&) at ??:?
#7  ? at ??:?
#8  __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#9  ? at ??:?
Floating point exception (core dumped)
johny0688 is offline   Reply With Quote
Old   February 19, 2017, 18:31
Agustín Villa
agustinvo is on a distinguished road
I am not an expert of compressible simulations, but are you sure that your pressure field is ok? In compressible flow, I think having a 0 Pa pressure is not good...
Can you show the thermophysical properties fiel
agustinvo is offline   Reply With Quote
Old   February 20, 2017, 04:42
Jan Surwiło
Thank you for your interest in my topic. At the beginning I have to say that I'm not very good in theory of fluid flow. I used to work with Fluent and CFX and never wandering how it works deep inside. I just trust results it gives. When I start working with OpenFOAM i realized that it is necessary to understand the basics physics to calculate e.g. k and epsilon. So I have much to learn.
In Fluent and CFX it is possible to set pressure boundary condition with 0 Pa and velocity inlet for compressible (ideal gas) model. So I guess my settings are wrong.
Here is the thermophysical properties:
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "constant";
    object      thermophysicalProperties;
thermoType
    type            hePsiThermo;
    thermo          hConst;
    specie          specie;
mixture
    specie
        nMoles      1;
        molWeight   28.9;
    thermodynamics
        Cp          1007;
        Hf          0;
    transport
        As          1.4792e-06;
        Ts          116;
BTW
I tried to find any explanation what As Ts and Hf is but I didn't find any even in FOAM guide. Is any instruction I can find all abbreviation?
Thank you in advance
Old   October 15, 2019, 10:53
Default As, Ts Sutherland Model
Wan Li
Dr.Wan_Li is on a distinguished road
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
thermoType
    type            hePsiThermo;
    thermo          hConst;
    specie          specie;
mixture
    specie
        nMoles      1;
        molWeight   28.9;
    thermodynamics
        Cp          1007;
        Hf          0;
    transport
        As          1.4792e-06;
        Ts          116;
BTW
As and Ts relate to Sutherland model for viscosity calculation. Please check the following link : https://www.cfd-online.com/Wiki/Sutherland%27s_law
Hf = heat of fusion :
Check following link on thermodynamic models : https://www.openfoam.com/documentati...mophysical.php
Dr.Wan_Li is offline   Reply With Quote
Old   June 1, 2021, 13:23
Smile
mm66 is on a distinguished road
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
thermoType
    type            hePsiThermo;
    thermo          hConst;
    specie          specie;
mixture
    specie
        nMoles      1;
        molWeight   28.9;
    thermodynamics
        Cp          1007;
        Hf          0;
    transport
        As          1.4792e-06;
        Ts          116;
BTW
Hi Jan,
I'm facing exactly the same issue with rhoSimpleFoam. Just wondering if you managed to solve the issue at the end. Please advise
Cheers,
MJ
mm66 is offline   Reply With Quote
rhosimplefoam error
[blockMesh] blockMesh with double grading. spwater OpenFOAM Meshing & Mesh Conversion 92 January 12, 2019 10:00
DPM udf error haghshenasfard FLUENT 0 April 13, 2016 07:35
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh gschaider OpenFOAM Community Contributions 300 October 29, 2014 19:00
OpenFOAM without MPI kokizzu OpenFOAM Installation 4 May 26, 2014 10:17
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 18:51
