buoyancyPimpleFoam surface temperature set-up
Old   February 14, 2017, 14:34
Default buoyancyPimpleFoam surface temperature set-up
Sharon
foamingMouth is on a distinguished road
I'm using buoyancyPimpleFoam to model heat-driven flows off a hot mass.
Let's say my hot mass is cylindrical and there is insulation around the sides (but not at the top or bottom) with a narrow gap between the hot mass and the insulation material. I need to work out how fast the flow through that gap will get if natural convection prevails.
Using a basic model I have got it working if the temperature delta between the air and the hot mass is 100K, but my temperature delta is closer to 600K. When I put the real value of temperature into the 0/T set-up file for the hot mass I cannot control my courant number and foam aborts.
I've dropped my timestep in controlDict to 5e-5, with no luck.
Q: Is there any way to heat my mass up during the simulation so that it doesn't go through the initial shock?
Thanks in advance...
foamingMouth is offline   Reply With Quote
Old   February 14, 2017, 16:20
Alexey Matveichev
alexeym has a spectacular aura aboutalexeym has a spectacular aura about
Send a message via Skype™ to alexeym
Use SemiImplicitSource? You can find description in $FOAM_SRC/fvOptions/sources/general/semiImplicitSource/SemiImplicitSource.H. In your case this source should have type scalar, field should be T, you can use only explicit part.
alexeym is offline   Reply With Quote
Ansys SIG$ILL error loth ANSYS 3 December 24, 2015 06:31
unexpected constant Temperature on a clip surface Sungki OpenFOAM Running, Solving & CFD 0 August 4, 2015 05:50
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 07:27
[ICEM] Automatic mesh generation script surface intersection problem stuart23 ANSYS Meshing & Geometry 0 May 13, 2011 02:10
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found piprus OpenFOAM Installation 22 February 25, 2010 14:43
