Common setup for p_rgh in complete open domains |
September 14, 2020, 15:47 |
#21 |
Tobias Holzmann
Rep Power: 51 |
I don't think it is a solver-bug but there is probably something missing I don't get until now or there is no appropriate boundary condition (and I don't have time to investigate into that problem). So you have to check it out yourself.
Keep foaming, Tobias Holzmann |
October 6, 2021, 08:48 |
#22 |
Thiago Parente Lima
Rep Power: 15 |
Hi everybody,
I'm currently working on a problem of natural convection in a open domain using buoyantPimpleFoam and, as many of you, I faced the same problems on the outlet boundary, say, backflow, accelarating flow, divergence, etc. I tried different combinations of boundary conditions, most of them discussed here in this thread. Recently I found this work which suggests the combination for p_rgh/U of fixedFluxPressure/zeroGradient for the top boundary and totalPressure/pressureInletOutletVelocity for the sides and bottom boundaries. I tried those on a test case attached and I've got a good result for the flow field on outlet (see video). In my case the bottom part of the domain is a wall. The boundary conditions were the following: Pressure: p_rgh Code:
dimensions [1 -1 -2 0 0 0 0]; internalField uniform 101325; boundaryField { outlet { type fixedFluxPressure; value $internalField; } sides { type totalPressure; p0 $internalField; value $internalField; } heat { type fixedFluxPressure; value $internalField; } base { type fixedFluxPressure; value $internalField; } frontAndBack { type empty; } } Code:
dimensions [0 1 -1 0 0 0 0]; internalField uniform (0 0 0); boundaryField { outlet { type zeroGradient; } sides { type pressureInletOutletVelocity; inletValue uniform (0 0 0); value uniform (0 0 0); } heat { type noSlip; } base { type noSlip; } frontAndBack { type empty; } } Code:
dimensions [0 0 0 1 0 0 0]; internalField uniform 293.15; boundaryField { outlet { type inletOutlet; inletValue uniform 293.15; value uniform 293.15; } sides { type inletOutlet; inletValue uniform 293.15; value uniform 293.15; } heat { type fixedValue; value uniform 303.15; } base { type zeroGradient; } frontAndBack { type empty; } }
Fields of interest: buoyantFoam, chtMultRegionFoam. Last edited by thiagopl; October 6, 2021 at 09:29. Reason: Deleting comments on the p_rgh file. |
May 11, 2022, 03:27 |
#23 |
Marco Müller
Rep Power: 13 |
Just contributing my findings, since I had the same issue, in case someone will find it helpful:
- I was not able to solve my (steady state) problem with buoyantBoussinesqSimpleFoam. It seems to have a current (v2006 for me) implementation that makes it difficult to deal with openings, see: Wrong implementation of the Boussinesq assumption in heat transfer solvers - Using buoyantSimpleFoam worked fine for me (without momentumPredictor, which introduced the same artificial convection with middle speed velocities as buoyantBoussinesqSimpleFoam) - BC setup: --- lower opening ("inlet"): prghTotalPressure + pressureInletOutletVelocity --- upper opening ("outlet"): fixedFluxPressure + pressureInletOutletVelocity - lastly - since I also had forced convection inside my domain -, I successfully used the limitVelocity option to get a stable initialization |
July 26, 2023, 08:30 |
#24 |
Rep Power: 5 |
Following the release of OpenFOAM v11, I also want to share some recent tests I did about natural convection and open boundaries since I have been looking into it quite a lot. I think I finally have a decent setup for a steadystate simulation using the fluid solver of OF v11 (similar to buoyantSimpleFoam).
My case is a simple hot box inside a fully open domain, so the air can come and leave frome any side. I used OpenFOAM v11 because it includes a switch to initialize the hydrostatic pressure in fvSolution so you can use the ph_rgh field and the prghTotalHydrostaticPressure condition in p_rgh. In OpenFOAM v2306, there is a functionObject that does the same initialization but I have yet to try it Here are the boundary conditions: p Code:
internalField uniform 101325; boundaryField { #includeEtc "caseDicts/setConstraintTypes" ".*" { type calculated; value uniform 101325; } "(sky|bottom|walls)" { type calculated; value uniform 101325; } "vol.*" { type empty; } } Code:
internalField uniform 0; boundaryField { #includeEtc "caseDicts/setConstraintTypes" ".*" { type fixedFluxPressure; value $internalField; } bottom { type prghTotalHydrostaticPressure; meanValue $internalField; p0 $internalField; value $internalField; } sky { type prghTotalHydrostaticPressure; meanValue $internalField; p0 $internalField; value $internalField; } walls { type prghTotalHydrostaticPressure; meanValue $internalField; p0 $internalField; value $internalField; } "vol.*" { type empty; } } Code:
internalField uniform 0; boundaryField { ".*" { type fixedFluxPressure; value $internalField; } bottom { type fixedFluxPressure; meanValue $internalField; p0 $internalField; value $internalField; } sky { type fixedValue; meanValue $internalField; p0 $internalField; value $internalField; } walls { type fixedFluxPressure; meanValue $internalField; p0 $internalField; value $internalField; } "vol.*" { type empty; } } Code:
internalField uniform (0 0 0.0); boundaryField { #includeEtc "caseDicts/setConstraintTypes" ".*" { type fixedValue; value $internalField; } walls { type slip; } bottom { type zeroGradient; //inletValue uniform (0 0 0); value $internalField; } sky { type zeroGradient; //pressureInletOutletVelocity; inletValue uniform (0 0 0); value $internalField; } walls { type zeroGradient; //pressureInletOutletVelocity; inletValue uniform (0 0 0); value $internalField; } "vol.*" { type empty; } } Code:
internalField uniform 293.15; boundaryField { ".*" { type zeroGradient; value uniform 293.15; //value $internalField; } hot_walls { type fixedValue; value uniform 393.15; } "(sky|bottom|walls)" { type inletOutlet; inletValue uniform 293.15; value $internalField; } "vol.*" { type empty; } } Code:
dimensions [1 -1 -2 0 0 0 0]; value 101325; Code:
PIMPLE { momentumPredictor no; nNonOrthogonalCorrectors 1; //pRefCell 0; //pRefValue 0; //consistent yes; hydrostaticInitialisation yes; nHydrostaticCorrectors 10; } Code:
ddtSchemes { default steadyState; } gradSchemes { default cellLimited Gauss linear 1; } divSchemes { default none; div(phi,U) bounded Gauss linearUpwindV default; div(phi,K) Gauss linearUpwind default; div(phi,h) bounded Gauss linearUpwind default; div(phi,k) bounded Gauss linearUpwind default; div(phi,epsilon) bounded Gauss linearUpwind default; div(phi,omega) bounded Gauss linearUpwind default; div(((rho*nuEff)*dev2(T(grad(U))))) Gauss linear; } laplacianSchemes { default Gauss linear uncorrected; } interpolationSchemes { default linear; } snGradSchemes { default uncorrected; } wallDist { method meshWave; } Code:
thermoType { type heRhoThermo; mixture pureMixture; transport const; thermo hConst; equationOfState perfectGas; specie specie; energy sensibleEnthalpy; } dpdt off; mixture { specie { molWeight 28.96; } thermodynamics { Cp 1004.4; Hf 0; } equationOfState { rho 1.2; pRef 101325; } transport { mu 1.831e-05; Pr 0.705; } }
Here is a picture of the temperature field with the surface LIC representation of the velocity. It looks decent to me but I would like to have other opinions on this Cheers! |
July 26, 2023, 15:54 |
#25 |
Thiago Parente Lima
Rep Power: 15 |
Hi Alczem,
Nice work. Although I posted this and also proposed this thread, which lead to conclusions, I still have problems in setting up natural convection problems in open domains. I found that OF v10 also includes this switch to initialize the hydrostatic pressure in fvSolution. I'm testing your setup, but in a transient case (good results by now!). I 'ill post the case here once I have conclusive results.
Fields of interest: buoyantFoam, chtMultRegionFoam. |
July 26, 2023, 16:01 |
#26 |
Rep Power: 5 |
Hey!
I remember reading your various posts, I think I read almost every thread related to this kind of simulation Yep, the switch was already implemented in OF v10, but I mainly use the ESI version and only recently have I been using the foundation version which has some pros (and cons, still figuring it out!). From some posts (by Tobias Holzmann I think), it sounded as if free convection might only be properly simulated through transient computation, or at least using a transient initial state to initialize the steady run, which is... not encouraging! I tried local time stepping and large CFL numbers but it still so slow, especially if you are simulating fluids and solids in a CHT case hopefully some common setup will emerge from all our tests |
July 27, 2023, 07:38 |
#27 |
Rep Power: 5 |
Back again with a similar case to my previous post, only on a much larger domain (which is 2D now and triangles only, I meshed quickly with Salome and had to be fast).
The pressureInletOutletVelocity condition seems actually more stable than zeroGradient, but they achieve very similar results. A lot of undesired currents remain present near the boundaries and I did not manage to completely mitigate their effects. They are also present when the hot box was disabled to try to reach a perfectly still atmosphere. Overall I am pleased with the results, but it is slow: it takes more than 5000 iterations to have a satisfactory flow. Maybe the numerics need more tinkering and other boundary conditions can achieve similar results faster. I still take this as a win |
October 5, 2023, 22:19 |
#28 |
Ali
Rep Power: 10 |
Hi Bodo1993,
It is about three years since your post. I hope you have had found a solution to this problem and are able to share it with me. I am facing exactly the same issue. Thanks, Ali |
October 5, 2023, 22:33 |
#29 | |
Ali
Rep Power: 10 |
Hi Bodo1993, It is about three years since your post. I hope you have had found a solution to this problem and are able to share it with me. I am facing exactly the same issue. Thanks, Ali |
p_rgh open domain |
MESHING A complete wing setup with SLAT,WING,FLAP for ACOUSTICS | AS_Aero | Pointwise & Gridgen | 3 | July 25, 2013 08:27 |
Problem installing on Ubuntu 9.10 -> 'Cannot open : No such file or directory' | mfiandor | OpenFOAM Installation | 2 | January 25, 2010 09:50 |
Version 15 on Mac OS X | gschaider | OpenFOAM Installation | 113 | December 2, 2009 10:23 |
DxFoam reader update | hjasak | OpenFOAM Post-Processing | 69 | April 24, 2008 01:24 |
OpenFOAM with IBM AIX | matthias | OpenFOAM Installation | 20 | March 25, 2008 02:36 |
