codeDict Error Parabolic Power Law Inlet Velocity Profile
Old   January 1, 2017, 18:12
Post codeDict Error Parabolic Power Law Inlet Velocity Profile
Sindibad is on a distinguished road
Hello everyone,
I have recently been attempting to create a case using HELYX-OS 2.4.0 and OpenFOAM 4.1. In the case, I am modelling flow around a scaled down building (CAARC) with LES. However, I was interested in implementing a parabolic velocity profile using the power law.
In order to do this, I must replace part of the code contained in the U file that is within the 0 folder which is within the case file. After adding some code into the controlDict file to measure pressure at certain locations as well as other data like drag and lift coefficients, the case was running fine using pimpleFoam. However, after replacing the bit of the code I obtain the following error:
|  \\    /   O peration     | Version:  4.1                                   |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
Build  : 4.1-1e03d68d4f4e
Exec   : pimpleFoam
Date   : Jan 01 2017
Time   : 16:20:17
Host   : "Sindibad"
PID    : 12510
Case   : /home/Sindibad/CAARC_LES_3D_4_SERIAL_3_UNTOUCH
nProcs : 1
allowSystemOperations : Allowing user-supplied system call operations
Create time
Create mesh for time = 0
PIMPLE: Operating solver in PISO mode
Reading field p
Reading field U
--> FOAM FATAL IO ERROR:
cannot open file
file: /home/Sindibad/CAARC_LES_3D_4_SERIAL_3_UNTOUCH/system/codeDict at line 0.
    From function regIOobject::readStream()
    in file db/regIOobject/regIOobjectRead.C at line 86.
FOAM exiting
The U file within the 0 folder contains the following code:
|       o          |                                                          |
|    o     o       | HELYX-OS                                                  |
|   o   O   o      | Version: v2.4.0                                           |
|    o     o       | Web:     http://www.engys.com                            |
|       o          |                                                          |
FoamFile
    version 2.0;
    format ascii;
    class volVectorField;
    location "0";
    object U;
dimensions [ 0 1 -1 0 0 0 0 ];
internalField uniform (0.0 0.0 0.0);
boundaryField
    Inlet
       type fixedValue;
       value uniform (4 0 0);
    Outlet
        type zeroGradient;
        value uniform ( 0.0 0.0 0.0 );
    Right
        type symmetryPlane;
    Left
        type symmetryPlane;
    Bottom
        type fixedValue;
        value uniform ( 0 0 0);
    Top
        type symmetryPlane;
    CAARC
        type fixedValue;
I have not been able to find any errors which are the same elsewhere. Can anyone help me understand why this error is coming up? I would be greatly appreciative if anyone could help me in understanding how to fix this error.
I have attached a link with all the files inside if they are required to be seen.
The case file is named CAARC_LEs_3Dcfdonline (the system file contains the modified controlDict file)
The folder in the google drive also contains the modified controlDict by itself, as well as the U file which I have been inserting in the 0 folder of the case file.
Again, I would appreciate any input on how to fix this error.
Many Thanks!
https://drive.google.com/open?id=0B7...3M0VzZNM1A0cE0
Last edited by Sindibad; January 1, 2017 at 21:08. Reason: Including the U file's code
Sindibad is offline   Reply With Quote
codedict, parabolic inlet, power law, profile boundary, velocity bc
Inlet boundary condition with existed velocity profile wanjia SU2 9 May 10, 2017 06:33
Multiphase flow - incorrect velocity on inlet Mike_Tom CFX 6 September 29, 2016 02:27
simpleFoam: Non-uniform mesh near inlet & outlet causes incorrect velocity profile? Zaphod'sSecondHead OpenFOAM Running, Solving & CFD 0 January 28, 2015 06:17
Inlet Velocity Profile BC - Floating Point exception during solution initialization Janshi STAR-CCM+ 4 March 14, 2012 11:21
[swak4Foam] Scale discrete inlet velocity profile with groovyBC cboss OpenFOAM Community Contributions 1 June 20, 2010 14:02
