buoyantBoussinesqPimpleFoam for steady laminar flow with heat transfer. |
December 22, 2016, 09:59 |
Saurav Kumar
Rep Power: 10 |
buoyantBoussinesqPimpleFoam is used for Transient solver for buoyant, turbulent flow of incompressible fluid.
can i use it for steady laminar flow, incompressible, without bouyanct force. by using g= 0 m/s^2, model=laminar and deltatime = 1 thank you. Regards srv |
December 22, 2016, 10:08 |
#2 | |
Kevin van As
Rep Power: 21 |
Use buoyantBoussinesqSimpleFoam Laminar: Just turn off turbulence modelling in the "constant/turbulenceProperties" file Incompressible: Yes Without buoyancy: If you set the buoyancy force will be zero. However, gravity will be off as well, is that what you want? If not, you can just edit the solver and delete the buoyancy force. |
December 22, 2016, 10:34 |
Saurav Kumar
Rep Power: 10 |
Usage: icoTempFoam [OPTIONS] options: -case <dir> specify alternate case directory, default is the cwd -noFunctionObjects do not execute functionObjects -parallel run in parallel -roots <(dir1 .. dirN)> slave root directories for distributed running -srcDoc display source code in browser -doc display application documentation in browser -help print the usag could you please help me to figure it out what am i doing wrong? Thank you |
Question about heat transfer simulation | Anna Tian | Main CFD Forum | 0 | January 25, 2013 19:53 |
Heat Transfer Coefficient in Compressible Flow 3D turbine cascade | Karkoura | CFX | 0 | March 10, 2011 16:35 |
Pipe Flow Heat Transfer | Saima | CFX | 5 | January 30, 2011 17:41 |
Heat Transfer boundary conditions for engine coolant flow simulation | rajuks | Main CFD Forum | 0 | February 15, 2010 10:04 |
Flow around pipes - heat transfer coefficient on the wall of pipe | doodek | Main CFD Forum | 2 | November 23, 2009 09:48 |
