DES Spalart-Allmaras right BC by no wall model?
Old   December 14, 2016, 11:45
Default DES Spalart-Allmaras right BC by no wall model?
The_Kaiser is on a distinguished road
Hey Foamers!
I wand to compare the behaviour of walls with the S-A turbulence model in a DES simulation. My first calculation went for 200s to initialize the flow, then I started averaging my fields.
My BC for wall modelling were:
nut:
wall {
     type    nutUSpaldingWallFunction;
     value   uniform 0;
nuSGS:
wall {
     value     uniform 0;
Now I want to start a calculation from the 200. second. Would it be a good idea, to change nuSgs to zeroGradient? or to fixed value 0 ? my y+ < 1 everywhre and I want to know, if the results will be the same as with wall modelling
And what should I do with "nut"? Actually, it's not being written out in the next timesteps, I had it only in "0". Does it mean, I need it only for initializing the flow?
The_Kaiser is offline   Reply With Quote
Old   December 15, 2016, 23:44
Did nobody a DES with Spalart-Allmaras?
Sent from my iPhone using CFD Online Forum mobile app
Old   December 21, 2016, 06:40
Bazinga is on a distinguished road
I am just now starting with S-A DES, DDES and IDDES - till now I always used Spaldings law. Here is a thread where someone used wall functions and no wall functions for a LES, maybe it helps:
LES WallFunctions in O.F. 2.2.0 (nutUSpaldingWallFunction)
Which version of OpenFOAM are you running? Because I use 4.0 and used the motorbike tutorial as a foundation for my simulations. I did not have a nuSGS file but nut and nuTilda. nut was saved in each time step as well as nuTilda for me.
Bazinga is offline   Reply With Quote
Old   February 23, 2017, 07:27
I was running it with OF 2.3. nut was only needed in 0, for the simulation. the stramnge thing was, when I run for example yPlusLES, I had to copy the nut file into the timestep, that interested me
Natural convection in a closed domain STILL NEEDING help! Yr0gErG FLUENT 4 December 2, 2019 01:04
How dose DES model treat for the near wall region? zlf1986 FLUENT 0 April 20, 2014 12:17
Radiation interface hinca CFX 15 January 26, 2014 18:11
A few questions about Spalart Allmaras model and y seb62 OpenFOAM Running, Solving & CFD 8 January 15, 2011 14:09
Numerical integration of Spalart Allmaras turbulence model RenardP Main CFD Forum 0 June 11, 2009 15:53
