how to initalize an expressionField for the walldistance?
Old   December 12, 2016, 10:55
Question how to initalize an expressionField for the walldistance?
David Kinast
david112 is on a distinguished road
Hi Foamers,
I need to compute a field in complex geometries which stores the distance to the nearest wall for the whole field. This is needed for a custom meshing technique for LES. I tried something like:
alpha2Field {
        type         expressionField;
        writeControl    writeTime;
        writeTime    0;
        fieldName     alpha2;
        expression     "dist()";
        autowrite    true;
unfortunately I am not able to aviod the Error like:
Creating expression field alpha2 ...Selecting patchDistMethod meshWave
[0]
[0]
[0] --> FOAM FATAL ERROR:
[0] At least one plane coefficient must have a value
[0]
[0]     From function void Foam::plane::calcPntAndVec(const scalarList&)
[0]     in file meshes/primitiveShapes/plane/plane.C at line 51.
[0]
Im usig OF4.1 on ubuntu 16.04 LTS
I hope someone is able and wants to help me. and cant imagine that its endless complicated.
regards,
David
david112 is offline   Reply With Quote
Old   March 23, 2017, 03:23
M. Montero
be_inspired is on a distinguished road
Did you solve the issue?
It seems like dist() does not work in OF4 and the approach should be different. dist() worked on OF2.1.1 for me
be_inspired is offline   Reply With Quote
expressionfield, walldist patch distance
[swak4Foam] Using fieldAverage together with swak4foam expressionField tiam OpenFOAM Community Contributions 33 December 18, 2016 08:49
[swak4Foam] swakFoam - expressionField marluc OpenFOAM Community Contributions 1 April 22, 2015 13:50
Problems creating a volScalarField with expressionField function-object zfaraday OpenFOAM Running, Solving & CFD 2 January 12, 2015 08:49
[swak4Foam] expressionField aylalisa OpenFOAM Community Contributions 1 October 28, 2014 18:42
