Open channel Boundary Conditions
Old   November 23, 2016, 14:12
Default Open channel Boundary Conditions
Milad
Milad Mohassel is on a distinguished road
Hi dear Foamers
I am trying to run an 2 phase flow in Version 2.4 since methods are changed from 2.3 for interFoam.
and I have problems with that.
1. my first problem is should I Split both outlet and inlet in to 2 face,(water and air separately)?
I caught the free surface (alpha.water) correctly but for Velocity I just Need the water velocity but air have non zero velocity too.
there is my U and alpha.water
any ideas?
thanks
the first 2 codes have 2 inlets
|  \\    /   O peration     | Version:  2.4.0                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      ascii;
    class       volScalarField;
    object      alpha.water;
dimensions      [0 0 0 0 0 0 0];
internalField   uniform 0;
boundaryField
    inlet-air
        type            fixedValue;
        value           uniform 0;
    inlet-water
        type            fixedValue;
        value           uniform 1;
    outlet
    type         zeroGradient;
    atmosphere
             type         inletOutlet;
            inletValue      uniform 0;
                value           uniform 0;
        walls
           type            zeroGradient;
        rib
           type            zeroGradient;
        front
                type empty;
        back
                type empty;
FoamFile
    version     2.0;
    format      ascii;
    class       volVectorField;
    object      U;
// * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * //dimensions      [0 1 -1 0 0 0 0];
internalField   uniform (0.1 0 0);
boundaryField
inlet-air
        type            fixedValue;
        value           uniform (0 0 0);
    inlet-water
       type      fixedValue;
        value    uniform (0.1 0 0);
    outlet
        //type       zeroGradient;
        type            pressureInletOutletVelocity;
    atmosphere
   walls
       type            fixedValue;
 rib
        type            fixedValue;
        front
                type empty;
        back
                type empty;
FoamFile
    version     2.0;
    format      ascii;
    object      alpha.water;
boundaryField
    inlet//has changed from inlet-water & inlet-air to inlet
      type            variableHeightFlowRate;
        lowerBound      0.0;
        upperBound      0.5;
        value           uniform 1;
    outlet
    //type        inletOutlet;
    //inletValue    uniform 0;
    type         zeroGradient;
    atmosphere
        type         inletOutlet;
            inletValue      uniform 0;//Like Spillway tut
                value           uniform 0;
        walls
           type            zeroGradient;
        rib
           type            zeroGradient;
        front
                type empty;
        back
                type empty;
FoamFile
    version     2.0;
    format      ascii;
    object      U;
boundaryField
        inlet
               type            fixedValue;
        outlet
        type         zeroGradient;
     atmosphere
               phi             phi;
    walls
               type            fixedValue;
       rib
        type            fixedValue;
        front
                type empty;
        back
                type empty;
at the end I use 0.9 for upper bound but I get nothing!
lowerBound 0.0;
upperBound 0.9;
value uniform 1;
Milad Mohassel is offline   Reply With Quote
Old   December 2, 2016, 03:25
Nima Samkhaniani
nimasam is on a distinguished road
whats wrong?
the air has a motion becuase there is shear stress between phases.
My Personal Website (http://nimasamkhaniani.ir/)
Telegram channel (https://t.me/cfd_foam)
nimasam is offline   Reply With Quote
boundary conditions, interfoam, open channel flow
what is swap4foam ?? AB08 OpenFOAM 28 February 2, 2016 02:22
Problem in setting Boundary Condition Madhatter92 CFX 12 January 12, 2016 05:39
Water subcooled boiling Attesz CFX 7 January 5, 2013 04:32
Problem installing on Ubuntu 9.10 -> 'Cannot open : No such file or directory' mfiandor OpenFOAM Installation 2 January 25, 2010 10:50
open channel flow boundary conditions yan FLUENT 0 July 5, 2005 00:36
