Jochen
Rep Power: 9 ![]() |
Hello everyone,
I’m trying to get into IB-simulations with foamExtend 3.2. I tried to do the movingCylinderInChannel tutorial but using my own surface mesh. While running potentialIbFoam, I generated a velocity field inside the new geometry (cf. screenshots with streamlines). The mesh was generated using ANSYS ICEM 16.0 and exported to a .stl-file. If I run surfaceConvert file.stl ibCylinder.ftr in FE, I generated a segmentation error. However, generating the .ftr-file works fine in openFoam. I have already tried coarser and finer meshes, and different geometries but the body always seems to be permeable. Everything except the triSurface mesh remained unchanged. Does anybody have an idea or can give me a clue? Thanks ![]() |
foam extend 3.2, immersed boundary method, pre-proccessing, surface meshing, tutorials |
[snappyHexMesh] SHM problem : KVLCC2 with appendage mesh | sc.park | OpenFOAM Meshing & Mesh Conversion | 1 | March 13, 2016 13:28 |
[mesh manipulation] Importing Multiple Meshes | thomasnwalshiii | OpenFOAM Meshing & Mesh Conversion | 18 | December 19, 2015 18:57 |
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation | tommymoose | ANSYS Meshing & Geometry | 48 | April 15, 2013 04:24 |
[Gmsh] 2D Mesh Generation Tutorial for GMSH | aeroslacker | OpenFOAM Meshing & Mesh Conversion | 12 | January 19, 2012 03:52 |
CFX4.3 -build analysis form | Chie Min | CFX | 5 | July 12, 2001 23:19 |
