Setting p0 to zero for totalPressure BC (OF4.1) |
November 18, 2016, 03:15 |
Louay
Rep Power: 10 |
Hallo Foamers,
i would like to simulate an inlet flow in a domain (cubic), which its boundaries (the six faces) should be at atmospheric pressure condition. My case is a little bit similar to the damBreak Case. My problem is, i don't know why is the p0 in the damBreak tutorial defined as the following: atmosphere { type totalPressure; p0 uniform 0; } shouldn't it be to 101325 Pa instead of 0 defined ? thanks in advance Cheers Louay |
December 2, 2016, 02:39 |
Nima Samkhaniani
Rep Power: 25 |
it depends that your flow is whether incompressible or compressible. in incompressible flow, it is typical to use relative pressure so it is assigned zero. but for compressible absolute pressure should be placed
My Personal Website (http://nimasamkhaniani.ir/) Telegram channel (https://t.me/cfd_foam) |
Fluent Parallelization Problem After AC Power Dropped | pawl | Hardware | 5 | November 13, 2016 06:08 |
using chemkin | JMDag2004 | OpenFOAM Pre-Processing | 2 | March 8, 2016 22:38 |
[snappyHexMesh] determining displacement for added points | CFDnewbie147 | OpenFOAM Meshing & Mesh Conversion | 1 | October 22, 2013 09:53 |
Cells with t below lower limit | Purushothama | Siemens | 2 | May 31, 2010 21:58 |
Warning 097- | AB | Siemens | 6 | November 15, 2004 04:41 |
