massFlowRateInletVelocity for Axisymmetric geometry
Old   October 27, 2016, 16:10
Default massFlowRateInletVelocity for Axisymmetric geometry
Rizwan Zahoor
rzahoor is on a distinguished road
Hello Respected Fellows,
I am using InterFoam to simulate the air and water flow in axisymmetric domain.
I have experimental data at inlet "Pressure and Mass flow rate" for both water and gas.
Just a short question if some one can help.
"Do I have to apply the mass flow rate like (Q/360)*4 (as i have created mesh wedge with 4 degree angle) or OpenFoam treats the same mass flow as in 3D like Fluent. "
Thanks in advance
rzahoor is offline   Reply With Quote
interfoam, massflow bc, openfoam, preprocessing
[ICEM] Volume Meshing Problem; YOUR GEOMETRY HAS A HOLE mariachi ANSYS Meshing & Geometry 5 May 30, 2018 03:52
Question about Geometry vs. Meshes EphemeralMemory ANSYS Meshing & Geometry 2 December 8, 2016 14:02
How to scale and translate the grid of particle data and STL geometry Saidul Tecplot 1 January 11, 2015 22:15
Running CFD parallel. There is no geometry file! CrashLaker SU2 6 April 10, 2014 04:08
[CAD formats] translating geometry from Abaqus to OpenFOAM skuznet OpenFOAM Meshing & Mesh Conversion 3 January 10, 2014 14:49
