Specifying Motion from .dat file Using Foam-Extend |
Nick
Rep Power: 9 ![]() |
Hello everyone,
First time poster here ![]() My usual OpenFOAM setup is OpenFOAM-4 where I have had success imposing motion on a body using both Laplacian and SBR dynamic mesh methods within the dynamicMeshDict and defining the patch motion within the 0/pointDisplacement file by specifying the bc type to be "solidBodyMotionDisplacement" and then the function to be "tabulated6DoFMotion". This then points to a .dat file defining the motion. So far so good however I have recently begun to investigate alternative mesh motion options and have read a great deal about RBF methods available within foam-extend. I am therefore now using foam-extend-3.2. My issue is that even ignoring the change of SBR-->RBF and sticking with SBR for now I cannot find a way to specify the body motion as the "solidBodyMotionDisplacement" option is no longer recognised as a valid bc type within foam-extend. I believe that tabulated6DoFMotion came out of what was previously referred to as "SKA" and this can be seen in the "foam-extend-3.2/tutorials/multiphase/interDyMFoam/ras/sloshingTank3D6DoF" case however this is using solidBodyMotionFvMesh within dynamicMeshDict whereas I require to use dynamicMotionSolverFvMesh hence my desire to specify this motion within the pointDisplacement file as I did with OF4. Am I overlooking something obvious or is this feature not possible within foam-extend? Thanks, Nick |
dat file, extend-3.2, pointdisplacement, solidbodymotion |
[swak4Foam] groovyBC in openFOAM-2.0 for parabolic velocity bc | ofslcm | OpenFOAM Community Contributions | 25 | March 6, 2017 10:03 |
[OpenFOAM.org] Error creating ParaView-4.1.0 OpenFOAM 2.3.0 | tlcoons | OpenFOAM Installation | 13 | April 20, 2016 17:34 |
simpleFoam parallel | AndrewMortimer | OpenFOAM Running, Solving & CFD | 12 | August 7, 2015 18:45 |
SparceImage v1.7.x Issue on MAC OS X | rcarmi | OpenFOAM Installation | 4 | August 14, 2014 06:42 |
[OpenFOAM] Annoying issue of automatic "Rescale to Data Range " with paraFoam/paraview 3.12 | keepfit | ParaView | 60 | September 18, 2013 03:23 |
