how is rhoSimpleFoam a compressible steady statefor compressible flow |
September 21, 2016, 10:48 |
annn
Rep Power: 10 |
how can rhoSimpleFoam be a compressible solver and a steady state solver at the same ime?
From what I know (please correct me if I am wrong) If its a compressible solver it means it takes into account that density is changing. if its a steady state you don't take time into account. so there comes my confusion it seems like the two are contradicting each other. |
September 22, 2016, 04:00 |
Rep Power: 11 |
The density can change in space, e.g. due to a certain temperature field present in your geometry. It can be stationary though, if in every single control volume, the density does not change over the time.
Another example: if you consider a steady-state solution for your velocity field, it doesn't mean that your velocity has to be constant in all your simulation domain. If the cross-section of a pipe gets smaller, the flow velocity will increase (assuming incompressible flow). This change in velocity is not connected with the time. Best regards Harald |
September 22, 2016, 04:23 |
annn
Rep Power: 10 |
thanks, that makes sense and great name 'hunger'
compressible flow, rhosimplefoam |
2D piston in steady closed pipe flow BC query! | lmarf88 | FLUENT | 0 | April 10, 2014 11:25 |
Solver for steady state compressible multispecies non-reacting flow? | inf.vish | OpenFOAM Running, Solving & CFD | 0 | October 1, 2013 02:09 |
how to set BC for compressible flow target mass flow rate | foolboy007 | FLUENT | 1 | April 4, 2012 04:24 |
compressible flow | maria teresa | FLUENT | 1 | September 7, 2007 17:58 |
How to determine whether flow is steady or unstead | Maliya,Barth | Main CFD Forum | 7 | October 7, 2006 03:26 |
